What did you do to your Roadster today? - Page 687 - Mercedes-Benz Forum
post #6861 of 6910 (permalink) Old 04-29-2019, 02:43 AM
Frank_S500's Avatar
Date registered: Nov 2004
Vehicle: MB CL500(C215);SL55(R129), SL63(R230)
Quoted: 50 Post(s)
Originally Posted by wlb50 View Post
Drove across town with the top down to our local German Restaurant's MaibockFest (celebration of summer?)
May Bock beer. More alcohol than regular german beer. Much stronger than typical US beer
https://en.m.wikipedia.org/wiki/Bock
Cheers, Frank
wlb50 likes this.
Live is too short to drive boring cars...
Frank_S500 is offline
post #6862 of 6910 (permalink) Old 05-04-2019, 07:33 PM
Date registered: Sep 2013
Vehicle: 1992 500SL, 1993 300SE, 1997 S320L, 2000 C230K, 2003 E500, 2005 Smart ForFour, 2008 Smart ForTwo
Quoted: 72 Post(s)
Today Iím inspecting my vacuum lines. First time doing this and Iím not sure if I should be amazed or not
If anyone know what the 2 lines disconnected are would help a million.
What did you do to your Roadster today?-img_1138.jpgWhat did you do to your Roadster today?-img_1139.jpg
BenzWillMakeHerDance is offline
post #6863 of 6910 (permalink) Old 05-04-2019, 09:44 PM
Quoted: 72 Post(s)
Also found out I need new distributor caps and rotors. The rotor but was on quite tight and couldnít manage to unscrew felt like it was going to strip the Allen key socket. Anyone experienced this before?
post #6864 of 6910 (permalink) Old 05-04-2019, 11:26 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 671 Post(s)
Cheers, Frank
Frank - I'll bet even you would like this place! It is a German Gastubbe in a California strip mall. 25 or so German beers. Even had a German TV crew fly here and do interviews!
Had a Kartofelpuffe and beer Friday.
wlb50 is offline
post #6865 of 6910 (permalink) Old 05-05-2019, 04:32 AM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
Originally Posted by BenzWillMakeHerDance View Post
Also found out I need new distributor caps and rotors. The rotor but was on quite tight and couldnít manage to unscrew felt like it was going to strip the Allen key socket. Anyone experienced this before?...
Yes, my project car... It's been siting outside from prior owner not driven for over 2 years. I had to use the allen key one size over (Standard) and gently tap it into the head of 2 of those rotor bolts (gently!)
Regards,
D
duh_vinci is offline
post #6866 of 6910 (permalink) Old 05-05-2019, 04:54 AM
duh_vinci's Avatar
Quoted: 252 Post(s)
As much as I enjoy the topless driving fun, the time has come to prep red devil for the full respray, started taking it apart. Amazing how much dust and dirt underneath of all the trim pieces after 23 years!
Going to pre-wire the car for a full sound system overhaul while it its all apart, perfect time for that... Going to do the final test fit of the front and rear aprons/lips on the bumpers and off they go along with the cladding...
Regards,
D
post #6867 of 6910 (permalink) Old 05-05-2019, 02:16 PM
MBguru's Avatar
Date registered: Jul 2016
Vehicle: 1999 SL500, 1999 SL60, 1999 CL60, 1999 S600 V12- Sold , 2011 Camaro 2SS RS ZL1, 2005 Z71 SS,
Quoted: 137 Post(s)
Since the weather here is rainy decided to do a few things ahead of schedule. Changed all the jacking points - the old ones were not looking too good. And did a spark plug change. What a difference between old and new. The old plugs, because the car does not run on higher RPM to often, were covered in soot. If anyone one needs a step-by-step here is the link hope it helps.
ID:	2510090   Click image for larger version
ID:	2510092   Click image for larger version
ID:	2510094   Click image for larger version
MBguru is offline
post #6868 of 6910 (permalink) Old 05-05-2019, 06:33 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 492 Post(s)
https://www.youtube.com/watch?v=aoa1PPZbOAE
Your old plugs look good to me. I have seen my fair share of sooty plugs (remember carb engines?)
I am surprised to see platinum; however...
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #6869 of 6910 (permalink) Old 05-06-2019, 12:41 AM
wlb50's Avatar
Quoted: 671 Post(s)
I am thinking of doing that to my 2000 E430 - how many of you use anti-seize? Funny thing is on my M119 SL500, 2-3 times I have changed the plugs 30,000 miles - and they are always a bit loose despite carefully torquing them to 30 Nm.
I am wondering if the anti seize is doing this?
In the case of the M113/M112, with 100K mile change interval, I sure don't want the plugs popping out of the holes.
The E430 has original plugs believe it or not - 97,000 miles.
wlb50 is offline
post #6870 of 6910 (permalink) Old 05-06-2019, 09:11 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 576 Post(s)
proper torque is dependent on lube or not on the threads and if lube what it is.
If you look at torque spec's for specfic sized bolts, many charts will list the spec for a "dry" bolt as well as spec's with various lubes on them. Lube usually means a lower torque spec.
So why with anti seaze you have loose plugs don't know.
Frankly, I've never used a torque wrench on plugs with a crush washer like are on the M119 plugs I've bought. I tighten them till I feel the crush washer collapse. I feel it starting to collapse and at least for me it is easy to tell when it has fully compressed. Then I stop. Done this on many other plugs with crush washers and I've never had one loose when I changed them, nor had one that was hard to remove either.
wlb50 and MBguru like this.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
I saw an SLR Roadster today... Jules. SLR Mercedes-McLaren SLR 5 01-09-2008 02:48 AM
Saw a new black lexus roadster today, really dumb looking car, chrome trim and then gold logo, yuck Jason Y R170 SLK-Class 3 02-14-2002 04:00 PM
Look what came in the mail today, coutesy My Roadster :D PJozefiak R170 SLK-Class 6 10-27-2001 07:13 AM
Hoping to see more first hand 32 reviews today. I think a couple of people are taking delivery today SteveL R170 SLK-Class 13 07-29-2001 10:13 AM
We got a new Car today.. Black roadster with Beige Leather interior...;-))) Kalle (currently in R170 SLK-Class 2 04-12-2001 07:57 AM
