300sl hard to start - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-08-2009, 02:36 PM Thread Starter
Date registered: Jun 2009
300sl hard to start
newly purchased 1991 300SL with 6 cyclinder, 5 speed is very hard to start for the first time in the morning- not cold weather. Once it warms up, all is ok. But getting it to go the first time really takes alot of cranking. What could be the problem? thanks for your help. Andy
ahats is offline
post #2 of 4 (permalink) Old 07-08-2009, 03:31 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 1390 Post(s)
Welcome to BenzWorld! I'll slide your query down to the R129 section, where you're far more likely to garner a helpful response. You might also consider completing your user profile, many find that information helpful in regard to providing you with the best possible response.
"2016 will go down in history as the year America lowered its expectations beneath the threshold of a first world country"
GeeS is offline
post #3 of 4 (permalink) Old 07-09-2009, 01:05 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 9 Post(s)
Send a message via Skype™ to msbarsi
Hi ahats and welcome aboard in our big friendly international family. Please remember to update your profile with your car year and location to hlep us help you in the best and quickest possible way.
You might want to get familiar with the advanced search feature of the forum and with the third blue sticky that's a "R129 all you have to know" guide.
Unfortunately I dont' have an answer for your problem but in a mattter of hours someone more knowledgeable than me will chime in with a possible solution.
Meanwhile how many miles has your car on the clock and how is your battery?
Cheers.
msbarsi is offline
post #4 of 4 (permalink) Old 07-09-2009, 06:55 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 600 Post(s)
Yes, and how much did you pay for your car? I have a 300SL 5-speeder that I might put on eBay, and I would like to have an idea what it might sell for.
Your cold-start problem may be due to a faulty coolant temperature sensor, a faulty Electro-Hydraulic Actuator (EHA) on the fuel distributor, or a faulty Overvoltage Protection Relay (OVP). I would begin by reading codes for the fuel injection and the ignition as explained here: https://www.benzworld.org/forums/r129...pre-94-a.html? If that gets you nowhere, then I would measure: (1) the resistance of the temperature sensor when cold, and (2) the current to the EHA. If you reach that point and need more help you can reply back.
bobterry99 is offline
No start-Hard start, multiple cranks, Help??? gquarrick W210 E-Class 13 11-24-2008 03:16 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 06:51 PM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
Hard to start up - 300SL-24 Guest (MBNZ) R230 SL-Class 2 03-08-2002 11:06 AM
