how to fix door lock on both doors? - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 04-21-2008, 01:01 AM Thread Starter
wheni stick in the key in my 1992 500SL. the key turns, but wont lock and unlock the doors.. it seems like a very common problem.. but i have no clue which part i need.. and i have no clue how i can remove the door handles?
scorpiox is offline
post #2 of 25 (permalink) Old 04-21-2008, 12:43 PM
retiringinmind's Avatar
Date registered: Sep 2007
Vehicle: 1990 SL500 6L AMG 103,000km
scorpiox, I have the same issue with my driver's side door lock. Do the doors unlock with the remote OK? Mine still do and until I have an issue with that, I was going to leave taking apart the door until I had to. (I have only gone so far as taking out the seat controller so far.) I'll be curious to follow along with your resolution of this issue.
Regards,
Daryl
retiringinmind is offline
post #3 of 25 (permalink) Old 04-21-2008, 01:30 PM
Date registered: Jul 2007
Vehicle: 1990 500SL
Lock
Mine also does not lock or unlock. I spent several hours removing the white plastic guard and tried to get the lock out. I finally sain F#@k it and put it back in. I'm sure there is a way to get that assembly out but I have not figured it out yet!!
poorscientist is offline
post #4 of 25 (permalink) Old 04-21-2008, 02:01 PM
WIS Manual
If it helps, here are the directions from the WIS manual. You would of course do them in order, 72-100, 72-240 and then 72-250. I suspect it might just be a linkage come off or broken. If any of you attempt this, please take pictures and let us know. As previously stated, I've only gotten as far as the seat control switch in 72-100. That was for a different issue.
Regards,
Daryl
Seadonkey likes this.
post #5 of 25 (permalink) Old 04-21-2008, 08:02 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 230 Post(s)
First you mast trouble shoot what is wrong do you hear noise on the lock in question.
The handle is removed by removing an Allen screw at horizontal with the lock remove a small portion of the rubber seal you will see a small hole loosen the screw.
The rest is from inside.
Regards.
aam.
aam is offline
post #6 of 25 (permalink) Old 04-21-2008, 11:29 PM Thread Starter
something is just broken or the link is not attached.. i have to remove the door handle, thats the hard part. i can sometimes use the remote to lock and unlock, but sometimes it doesnt work too.. I have to use the trunk with the key to lock and unlock the doors.
scorpiox is offline
post #7 of 25 (permalink) Old 04-22-2008, 08:16 AM
STEPH R129's Avatar
Date registered: Feb 2008
Vehicle: MB 500SL 1991
I have the same problem too on my driver side lock.
My key can do a complete 360 in the lock!
So far my remote work great so i did not freak out too much but i have to get that fix
eventualy.
If i remember well, there is a video in the sticky that show how to take the handle off.
Anybody get a complete 360 with key in the lock?
STEPH R129
STEPH R129 is offline
post #8 of 25 (permalink) Old 04-22-2008, 08:49 AM
Yes, there is a video on getting the door handle off all right. It looks very easy and simple, as long as you have the allen key. That answers scopriox' original question. But, what will this show me, other than me having a lock in my hand? We need to know why turning the key does not unlock the door.
post #9 of 25 (permalink) Old 04-22-2008, 09:03 AM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 826 Post(s)
As the lock looks so quick and easy to get out maybe if you take off the lock that works too, then compare them both to see why the other one doesn't work.
Now I have seen it is so easy I'm going to remove my black handles and spray them the same colour as the car.
I was going to mask them up for spraying but no need to now.
RedLiner is offline
post #10 of 25 (permalink) Old 04-22-2008, 11:19 AM
Vehicle: 1990 500SL
Allen set screw??
Thanks AAM, I think that was the missing piece. I was trying to squirl that hole mess through the door. I'll give it another shot. Help appreciated!!
Doors lock, trunk does not?? Stewart W163 M-Class 38 04-06-2010 11:05 PM
Help to fix driver's door lock? JimAB W201 190-Class 11 12-05-2007 10:00 AM
fs: Complete door lock assembly for a coupe (to fix the windows) snik For Sale/Wanted/Trade/Giveaway 0 04-25-2007 01:07 PM
Fix /buy door lock or Keyless entry ? sali W126 S,SE,SEC,SEL,SD,SDL Class 7 01-22-2005 04:52 PM
WARNING:Make sure your hatch door manual lock is set or the hatch door will not lock with the remote AC_ML W163 M-Class 10 12-17-2003 10:16 PM
