Headrest Gears - Mercedes-Benz Forum
post #1 of 124 (permalink) Old 09-13-2005, 04:55 AM Thread Starter
carlosamg's Avatar
Date registered: Jun 2005
Vehicle: GL350 CDI Euro 5 265 Hp
Headrest Gears
My passenger seat head rest wont move using the button on the door.The button sounds like its working if you get what i mean but the head rest does nothing.I t is stuck at its highest point at the moment and it wont budge even with hand pressure.Any ideas how i can solve this ?.The rest of the seat works fine.
carlosamg is offline
post #2 of 124 (permalink) Old 09-16-2005, 12:36 AM
Date registered: Dec 2002
Vehicle: 560sec
RE: Head rest wont lower
I have exactly the same problem. I had a good look at the head rest and cannot see how you can access that motor. Did you have any success?--I see that no one has had any suggestions so far. If my mechanic can come with something I will let you know.
Dukming is offline
post #3 of 124 (permalink) Old 09-16-2005, 02:34 AM
NZSL's Avatar
Date registered: Aug 2005
Vehicle: 1990 500SL
re: Headrest wont lower
Have you tried taking out the seat cushions to access the problem motor? I can't remember seeing that motor when i had the seat apart but It'll be there.
The job is an easy one and has been explained before.
1. remove bottom cushion by unscrewing the two large phillips head screws just in front of the cushion. (photo below) then pull cushion forwards to release.
2. remove upper cushion by finding the two small funny head screws at the bottom of the back of the seat. really get down behind the back of the seat to find these. and make sure you have the right screwdriver or you're wasting your time. Upper cushion then comes free easily.
3. You now have a good view of the guts of the seat. all the motors are in view as far as i can remember.
NZSL is offline
post #4 of 124 (permalink) Old 09-16-2005, 04:37 PM
Vehicle: 560sec
Oh so the motor for the headrest is in the bottom of the seat....Seems like the problem on my car is up the top. I can hear it trying to move but the gears seem stuck - presumably from lack of use.
Dukming is offline
post #5 of 124 (permalink) Old 09-16-2005, 07:17 PM
Date registered: Dec 2004
Vehicle: 2006 E320 CDI & 2002 CLK55 AMG Cabriolet
I have the same problem on my passenger seat. Getting to the motor is not too complicated but does require that you disassemble the bottom cushion, back cushion, and the entire seat belt cover and part of the assembly. The motor is at the top and has 2 plastic gears on the top of the motor. My gears are broken. I have to replace the motor. I have not checked on a price yet but my bigger concern is that you need to unscrew a bolt associated with seatbelt the has a red line on it. That tells me it probably has certain torque requirements that I am not familliar with. I hope this gives you a better idea. My guess is that it is probably 2 to 3 hours of work plus parts.
Pistolero63 is offline
post #6 of 124 (permalink) Old 01-10-2007, 08:49 AM
Date registered: Dec 2006
Vehicle: 1992 300sl auto
Headrest Gears Source for parts
Hi all. I got into my seat to fix the headrests. Basically the nylon gears above the seat belt have cracked. The gears are held on by a circlip and pop right off. Well the stealer wants $197 for the complete unit when only a $3 part is busted. Does any one know of a source for theses gears or a part#. I looked at the gears and could not see any part# on them. I have to repair both sides so $400 for two units is a bit steep!!
All help appreciated
grafy is offline
post #7 of 124 (permalink) Old 01-29-2007, 10:44 AM
head rest gears fixed
Hi all, well I managed to fix my stuck headrests. The problems was the two nylon gears located on the top of the seat. There are two gears for each side. One large, one slightly smaller. The larger gears had split and were spinning on the shaft. The headrests are dam near impossible to move with out being driven by the worm gear. What I did was remove the headrest transport, it is really quite easy. Search the videos of how to strip the seats . Then I took the assembly to a local gear supply, here we matched the gear sizes, I could not get the exact gears. The original gears are helical nylon, I replaced mine with straight cut mild steel. We could not match the spline pattern so I dry fitted the new gears and put a spot weld on the top of the shaft to the gear. The headrests work great now, although the metal gears are a tiny bit noisier but no biggie. this saved me over $500 in stealer prices just for parts. The whole project cost me $60 and some of my time to strip and replace seats.
Sorry no pictures as my camera was on loan
grafy is offline
post #8 of 124 (permalink) Old 09-26-2007, 11:54 PM
TheVpwr's Avatar
Date registered: Aug 2004
Vehicle: SL600 S420
Anyone with a photo of the gears?
I have the whole set motors and gears off '92 500SL
DRIVE IT LIKE YOU STOLE IT!!!
TheVpwr is offline
post #9 of 124 (permalink) Old 11-22-2008, 12:33 PM
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 18 Post(s)
Originally Posted by roadog View Post
How do I remove the headrests so I can install my new seat covers?
I've tried using the search function....basic and advanced...seems like most the time I get the response that the search I am doing is less than three words! I type in something like "how to remove head rests" definitely not less than three words!?
Clary, sorry your having problems but let me tell you my friend that you are attempting to undertake quite a bit of work because the seats are very complex. Are you sure you need to remove the headrest? If so, normaly I would point you to the Blue Stickies at the top of the forum that most people don't read. DARN!
So her is where I will send you:
https://www.benzworld.org/forums/r129...ed-topics.html then
https://www.benzworld.org/forums/r129...ml#post3194559 then
https://www.benzworld.org/forums/r129...-function.html and simply use the word 'headrest' or 'head rest' nothing more is needed. I usually start with ONE word so as not to confuse the Search Engine. Then I might try multiple words.
PS, if your are going to work on your car you need to purchase the Mercedes STAR Classic R129 DVD or go to https://www.benzworld.org/forums/r129...ml#post2379407 and consider a one day's worth of 'STAR TekInfo' or one year of 'ALLDATAdiy'.
lynns is offline
post #10 of 124 (permalink) Old 03-22-2009, 05:26 PM
s132008's Avatar
Date registered: Dec 2008
Vehicle: 1994 SL320 (R129), 2002 S500 (W220), 2006 S550, 2012 Ducati 848Evo Corse SE
Originally Posted by grafy View Post
Hi all, well I managed to fix my stuck headrests. The problems was the two nylon gears located on the top of the seat. There are two gears for each side. One large, one slightly smaller. The larger gears had split and were spinning on the shaft. The headrests are dam near impossible to move with out being driven by the worm gear. What I did was remove the headrest transport, it is really quite easy. Search for the videos of how to strip the seats. Then I took the assembly to a local gear supply, here we matched the gear sizes, I could not get the exact gears. The original gears are helical nylon, I replaced mine with straight cut mild steel. We could not match the spline pattern so I dry fitted the new gears and put a spot weld on the top of the shaft to the gear. The headrests work great now, although the metal gears are a tiny bit noisyer but no biggie. this saved me over $500 in stealer prices just for parts. The whole project cost me $60 and some of my time to strip and replace seats.
Hi Grafy, I started to fix the gear too but I couldn't take the unit out as the headrest was stucked. I think I need to remove the headrest before I can take out the unit for scratching out the nylon. Can you explain a little more on how to remove the head rest? The pic of the exposed parts is attached.
Thanks a lot.
s132008 is offline
What a AUT 4 gears GE must change to fit a 617A AUT 4 gears Zé Bocaina G-Class 7 05-28-2007 01:00 PM
Gears, gears -Again? fernweh G-Class 14 12-04-2005 09:21 PM
6.17 gears Tonyj G-Class 2 10-16-2004 02:05 PM
gears vdubpower W126 S,SE,SEC,SEL,SD,SDL Class 1 08-03-2004 02:16 PM
Dreaming of high gears........now im wishing for any gears!!!! peter G-Class 5 05-14-2002 03:22 AM
