door panel - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 03-14-2019, 01:46 PM
ceta4zng's Avatar
Date registered: Sep 2014
Vehicle: 2002 SL500 Silver Arrow
Quoted: 153 Post(s)
haven't had to take off my door panels yet - and I make a rule not to jump into discussions in which I do not have real experience with - but since you are desperate for an answer, I will try to help. In all my decades of working on cars, I have never experienced a door panel that can be removed in sections - and be easily reassembled with half on and half off the car. I'm not saying they don't exist - but I have never dealt with one.
So I would expect - in this case - that you should plan to remove the entire panel as a single unit and then you will have the access to complete your task with the least potential to damage other parts
ceta4zng is offline
post #12 of 17 (permalink) Old 03-14-2019, 01:54 PM
Date registered: Mar 2015
Vehicle: E500(1993) E220cdi(2004) SL500(1994)
Quoted: 80 Post(s)
Originally Posted by robm.UK View Post
Originally Posted by powergreen View Post
Come on guys.. it's not hard.
I just wanna know if the upper door panel liner come apart??
not the one with the door handle; but the upper one.
regards,
AFAIK they are one piece, but the leather liner and backing above the compartment can be separated.
Way to go would be to take the whole door panel off and see which of the upper moulded parts can be removed.
Thanks Robm!
I will do so.
powergreen is offline
post #13 of 17 (permalink) Old 03-14-2019, 02:02 PM
Quoted: 80 Post(s)
Thanks Ceta!
In fact I can manage to find another whole panel but on mine there are some wood trims and I prefer not to remove them...
I saw some sections of the panel being parted and sold on ebay(the handle+the lower storage compartment covering). So I thought may be the upper section could be separated too.
I will try to find a used panel and look carefully inside it. If it can be dismantled I will definitely replace the damage section otherwise I will replace the whole unit.
I will let you know...
Regards,
post #14 of 17 (permalink) Old 03-15-2019, 03:43 AM
ceta4zng's Avatar
Quoted: 153 Post(s)
Thanks Ceta!
Regards,
My apologies - I misunderstood the nuance of the question. My interpretation was that you merely wanted to replace the damaged part without removing the entire door panel - when I now believe you were asking if you were to take off the panel, can the damaged section be separated and taken to an upholstery shop for repair. I would expect that a reputable shop could deal with an entire panel just as easily as a single damaged section i if it were to come to that.
ceta4zng is offline
post #15 of 17 (permalink) Old 03-15-2019, 06:12 AM
Quoted: 80 Post(s)
Thanks Ceta!
Regards,
No issue me dear...
Once I will remove the panel I will carefully look at it and decide if I just take it to an upholstety shop or replace the whole unit...
Many thanks ..
Regards,
post #16 of 17 (permalink) Old 03-23-2019, 07:59 AM
Date registered: Feb 2019
Quoted: 4 Post(s)
I have removed both door panels replaced all speakers in my 99 SL500 very simple with the proper tools multiple pop clips on the edges along with some screws one behind the airbag emblem on the door into in the storage pocket pretty simple take your time not to destroy or break anything
Fishonchris is offline
post #17 of 17 (permalink) Old 03-23-2019, 08:01 AM
Quoted: 4 Post(s)
Re did speaker cloth as well
Ears likes this.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Help with door panel toddwess R170 SLK-Class 2 01-13-2006 04:55 AM
03 G500 Door panel pulled off when the door is closed The_Analyst G-Class 3 03-02-2004 01:38 PM
door panel CLK fan General Mercedes-Benz 3 02-23-2004 03:34 PM
Door panel joe_ca R170 SLK-Class 8 10-20-2003 10:56 AM
For those of you who have taken off the door panel on their ML. Please Help Kevin W163 M-Class 4 03-13-2002 11:05 AM
