Please help with resetting soft top controller - Page 6 - Mercedes-Benz Forum
post #51 of 57 (permalink) Old 04-09-2019, 09:04 AM
Date registered: Sep 2006
Vehicle: '07 S600, '00 E320 Wagon, other
Quoted: 19 Post(s)
1996 both windows stopped working
Hi, a great thread so here is another related problem. 1996 SL600 (hall sensors not microswitches so no controller resets with paper clips/LEDs like older models). In for a top replacement. Everything works perfectly. The top is down and windows are down. Battery disconnected/reconnected and top being raised (incorrectly) without windows normalization - of course the top goes up only to a vertical position. Manually pushed further and cloth of the top is removed.
Now both windows do not respond to windows up/down switches.
- STAR fault readout shows only that both windows are not normalized. All faults reset. No change
- Fuse 5 in trunk OK (covers windows and central locking, central locking works)
How to otherwise reset the RST/RV controller in addition to fault clearing? STAR actuation menu only shows the roll bar, am I missing the explicit RST/RV reset somewhere?
What would be a next step to diagnose? Note that the battery was being disconnect/reconnect before without problems, so blaming it for the RST/RV controller failure may be premature. Also (albeit incorrectly) the top was operated without windows normalized before without problems.
How to determine if the RST controller is good or faulty before jumping to replacing it? Any other ideas? Please help!! Thanks
George993 is offline
post #52 of 57 (permalink) Old 04-09-2019, 09:29 AM
Quoted: 19 Post(s)
Additional information (may or may not be relevant) - roll bar is down, top switch illuminated red, and Anti Theft Control Module (ATA) faults can not be reset. No idea is there is any link between ATA and windows/RST/RV controller
post #53 of 57 (permalink) Old 04-09-2019, 10:24 AM
Quoted: 19 Post(s)
And the battery (often a problem in cases like this) is good 13V
post #54 of 57 (permalink) Old 04-10-2019, 06:31 PM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 559 Post(s)
There is no "reset" of the RST controller of which I am aware. Of course, removing its source of power would cause it's software to reboot.
Look at the RST controller's "Actual Values" to see if the status of the window control switches are being read. If they are, the trunk fuses which power the windows are good, and you have no codes, then I would suspect the RST controller.
The windows can not be actuated from HHTWIN.
bobterry99 is offline
post #55 of 57 (permalink) Old 04-12-2019, 06:44 AM
Date registered: Feb 2010
Vehicle: 96 sl600,97 s420(gone) 96 CL600
Quoted: 167 Post(s)
For what its worth, after a recent dead battery on my 96 I had top light and roll bar light illuminated. Scanned with SDS and cleared faults, reset windows, reset steering sensor etc. no change. What worked was disconnecting the battery for a few minutes and reconnecting. It apparently does "reboot" the controller.
FATHERTIME likes this.
glepore is offline
post #56 of 57 (permalink) Old 04-13-2019, 08:40 AM
Quoted: 19 Post(s)
Thank you guys, I've disconnect the battery a few times, for short period of time and overnight. Same results in both cases. (No change). I think the status is being read, I'll double check. Also the big red top switch causes the latches to click when engaged, so something is working, but the top is not moving.
post #57 of 57 (permalink) Old 05-23-2019, 09:03 AM
Quoted: 19 Post(s)
Problem solved. Windows and the top are working fine. The way to fix the non-responsive controller (and non-working windows and non-working top) was to manually put up the convertible top and manually lock all the latches properly.
When the controller received some conflicting information from the latches/switches which were not closed/open in a way which made sense to it, the controller just froze and did nothing.
Once the feedback from latches/switches started making sense to it, it started operating again. This is 1996 btw.
1997 Soft top controller problem DuckZilla R129 SL-Class 4 07-10-2010 06:35 PM
Soft Top Controller Question alydon R129 SL-Class 3 12-02-2008 10:56 AM
99 R129 soft top possible controller issue? msc R129 SL-Class 1 05-15-2008 07:08 PM
Using windows without the soft top controller unit on a 1991? STEPH R129 R129 SL-Class 18 03-31-2008 03:06 PM
need help erasing soft top controller codes arjan R129 SL-Class 2 05-25-2007 04:23 PM
