WUR Vacuum lines - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old Yesterday, 11:30 AM
longbeach1's Avatar
Date registered: Dec 2015
Vehicle: 2003 E320 4matic wagon; 1979 450 SL
Quoted: 41 Post(s)
RD, you're correct.My car has A/C but it is non-op. Compressor doesn't have a belt to it any more.So, I wonder could I plug that line and move it to hose by AAV???
longbeach1 is offline
post #12 of 16 (permalink) Old Yesterday, 11:42 AM
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 165 Post(s)
Its worth a try. Do you also have the red line?
It went here on my old engine but was never sure if it was correct.
RaceDiagnostics is online now
post #13 of 16 (permalink) Old Yesterday, 01:31 PM
longbeach1's Avatar
Quoted: 41 Post(s)
Not sure about the red line. Is that the back of engine???
post #14 of 16 (permalink) Old Yesterday, 02:55 PM
Quoted: 165 Post(s)
It goes from the throttle body to the top of the distributor actuator.
post #15 of 16 (permalink) Old Yesterday, 05:48 PM
longbeach1's Avatar
Quoted: 41 Post(s)
RD, on my car I have a "Y" connection coming off the top of distributor actuator. One line goes deep into the front of intake manifold. Other one goes off to another "Y" connection that goes to a dual port temp sensor?? on front of intake manifold. I'll see if I can get some pics tomorrow.Anyway, moved that one line and did seem to make a difference, more responsive to throttle. This has been a long process.I've been doing this without proper instruments for measuring combustion,fuel pressure, etc..Initially I had this weird humming sound. That took most of last summer to find. Turned out that the fuel pressure was too high,I started removing shims from primary fuel regulator until it stopped. Then I've been dealing with a hard start when hot situation.I've been backing off little by little on the fuel mixture screw(inside FD ). This has gotten much better. I feel that I'm almost there. But, still have a throbbing at idle. Thanks for all your help...
post #16 of 16 (permalink) Old Today, 01:56 AM
Quoted: 165 Post(s)
A yes, I remember that on my old engine now, quite a few differences on the AC cars.
