Oil change on 88 560sl - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-08-2019, 11:42 PM Thread Starter
Date registered: Aug 2019
I'm changing the oil on my newly purchased 560sl with 53k miles. I don't know what oil the previous owner used and neither does he. Should I send my pilots for testing to find if its synthetic or conventional?
Ravi Singh is online now
post #2 of 14 (permalink) Old 08-09-2019, 11:57 AM
Date registered: Jul 2019
Vehicle: 1986 560SL
Quoted: 4 Post(s)
I've got a similar situation with an '86 560SL which we recently bought. But I wouldn't be concerned about what had been used before, just use a quality synthetic going forward. I'll likely use what I put in my Audis; Mobil-1 European 0W-40. By the way, I tend to dislike commenting on "oil threads" but your question was relevant to me. My main concern is getting a drain pan with enough capacity for that engine.
jimknock likes this.
Turbo510 is offline
post #3 of 14 (permalink) Old 08-09-2019, 03:04 PM Thread Starter
How much oil capacity is in that engine.
post #4 of 14 (permalink) Old 08-09-2019, 03:29 PM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 89 Post(s)
There are many oil threads on the forum. Do a search and read up on them. There are many different philosophies for which oil to use. I live in a warm climate, and my car has a 155,000 miles. So I use a heavier weight conventional oil, which has a higher viscosity and does not leak out as readily as synthetic. Oil, IMHO is one of those things where one size does not fit all. More important to keep it between the marks and change it regularly. Also, your engine holds nearly 10 quarts of oil
Franklyspeaking is online now
post #5 of 14 (permalink) Old 08-09-2019, 04:38 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
With filter it holds 8.5 US quarts.
It's in the owners manual. If you don't have one there is a link to the online service manual which contains the 560SL owners manual. It's in the EGv107 Sticky.
rowdie is offline
post #6 of 14 (permalink) Old 08-09-2019, 07:58 PM
Date registered: Jun 2018
Vehicle: 1988 R107 560SL
Quoted: 7 Post(s)
Rowdie, 8.5 Liter nearly 10 quarts.
Rudiger
Rudiger1960 is online now
post #7 of 14 (permalink) Old 08-10-2019, 04:35 AM
rowdie's Avatar
Quoted: 111 Post(s)
Rudiger
I stated 8.5 quarts not liters. Your math is also off. Go read the manual.
rowdie is offline
post #8 of 14 (permalink) Old 08-10-2019, 09:40 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
I just put in 9 qt so I don't have a half of a qt lying around
Between Samson and Delilah its 5 gal. 11qt in Samson, 9qt in Delilah.
roncallo is offline
post #9 of 14 (permalink) Old 08-10-2019, 10:16 AM
Date registered: Oct 2016
Vehicle: 1985 280SL (Euro)
Quoted: 49 Post(s)
I had heard that synthetic oil and older cars were not a good mix due to something in the oil that eroded old style seals and gaskets. Is this not so?
freshairfiend is offline
post #10 of 14 (permalink) Old 08-11-2019, 03:18 PM
Date registered: Nov 2018
Vehicle: w108 & w107
Yes from my experience this is the case. If the owners manual says use synthetic, then I'd use it, but if it were designed to run on Mineral or blended Oil, then that's what I would use. In my engines, I use mineral oil, preferably with a high Zinc content.
matthewz107 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
