1979 450 having issues starting it - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-07-2019, 07:17 PM Thread Starter
Date registered: Apr 2019
I'm not sure if I should start with fuel pumps,fuel distributor,injectors or? I bought the car running but ran rough. It's sat for 6 months and I got it to start but wouldn't idle but would spit n sputter on the pedal. I have another one and I was told fuel distributor was faulty and I had it rebuilt and that car runs fine. I just don't want to start throwing parts without an idea on how to go thru and figure out what may be the problem part. Any ideas on a path to take to check fuel system? Thanks in advance for your help!
Steve Erwin is offline
post #2 of 3 (permalink) Old Today, 02:55 PM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 110 Post(s)
Hi Steve, agree with you that the shotgun approach is not the most effective approach - you need to diagnose what's wrong first. I also have a 79 450SL and have had similar issues, cut the long story short in my case it was thermotime. Switch which was flooding the engine due to excessive fuel from the cold start valve.
It could be something else with your car though, and I'd encourage you to review the Encyclopaedia Germanica for R107 which has fantastic troubleshooting guides; it's a sticky on the main page. Have a look and let us know your thoughts.
miko1aj is offline
post #3 of 3 (permalink) Old Today, 07:23 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 131 Post(s)
I would start with vacuum checks, ignition reliability and fuel pressure tests in any case of undiagnosed start/run issues.
When you can confirm spark is there uninterrupted, blue in colour and that fuel.pressures are correct for the run condition,
Djenka018 is online now
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Troglodyte , Djenka018
