Dropped pin into timing chain cover and probably sump - options? - Page 6 - Mercedes-Benz Forum
post #51 of 57 (permalink) Old 08-11-2019, 11:59 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
Question Magnetic drain plugs
Originally Posted by miko1aj View Post
On a separate note, if you're unable to retrieve the pin you can consider getting a Dimple M26x1.5x16 Magnetic Drain Plug - this sucker is super strong and if the pin is ever in the vicinity it will get caught. I have two installed, second in the rear diff.
I wonder if they will fit my 380SL ?
Aussiemerc is offline
post #52 of 57 (permalink) Old 08-12-2019, 12:38 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 113 Post(s)
Indeed Graham, but my understanding so far is that we cannot ascertain if that pin is or is not magnetic... The plug won't do any harm and just might save the day.
Aussiemerc, you'd have to check your plug sizento confirm 100%. Dimple do a range of different sizes so I'm sure a fit can be found, have a look at their website.
Aussiemerc likes this.
miko1aj is online now
post #53 of 57 (permalink) Old 08-12-2019, 03:15 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 160 Post(s)
Well i did read that poster had a bore scope .They do come in a few sizes and small enough to get in to the drain hole of the sump .Take a look you might even find it basking in the gold liquid .
plinker17722 is offline
post #54 of 57 (permalink) Old 08-12-2019, 03:21 AM
Quoted: 160 Post(s)
Endescope
This is it purchased from Ebay few $ And you will get a hook and other items with it to help you fish it out .If you spot it them tape a small magnet --if its steel to remove it
ID:	2533880   Click image for larger version
ID:	2533882   Click image for larger version
post #55 of 57 (permalink) Old 08-12-2019, 02:22 PM Thread Starter
Premium Member
Date registered: Sep 2017
Vehicle: 1985 380SL
Quoted: 50 Post(s)
Premium Member
Well........I drained the oil and poked around with my borescope without success. I was on my back for about an hour looking around and finally gave up. At this point I've refilled it with oil and I'm going to run it as is. I still believe it is in the sump and I just had shit luck in getting to the location where it's sitting. It did not come out with the old oil as I dumped the catch pan. Thanks for all the feedback.
MrSpock is online now
post #56 of 57 (permalink) Old 08-12-2019, 03:27 PM
miko1aj's Avatar
Quoted: 113 Post(s)
Thanks for letting us know MrSpock - I hope the good fortune will not forsake you!
post #57 of 57 (permalink) Old 08-13-2019, 01:15 AM
Quoted: 160 Post(s)
We are all keeping an open mind in this one .I hope you have trouble free motoring for years to come . But i would get a sump magnet i have one in my W124 .Each time i drain the oil i check it for metal shards but as yet it is clear each time .The oil pump swirls the oil in the sump at high speeds and luck is it just might get picked up with the gizmo magnet.Good luck ..
