79 450SL accumulator and attached bits Qs - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-23-2019, 01:19 PM Thread Starter
Date registered: Jul 2019
Vehicle: 1979 450SL USA 058xxx
Quoted: 2 Post(s)
I rarely post on forums since my stuff is all kinda old, and others have solved the problems I face and the internet is good. But I'm trying to track down everything I need to replace the whole accumulator / fuel pump / filter cluster including all lines. I have found everything but the one (?) line coming from the damper. I found this lovely diagram here but not the associated part names.
https://www.benzworld.org/forums/att...tem-diag-2.jpg
I need 170 and 218 and their assorted bits. 218 looks like one t shaped line?
Thanks in advance and for so much info I rarely need to bug you at all.
CJQBrooklyn is offline
post #2 of 13 (permalink) Old 07-23-2019, 04:22 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
Smile Fuel pump part names
I think 170 is a compensating valve and 218 is a leak off line. Don't shoot me if I'm wrong!
According to the manual I have it was modified in Feb 1979.
Aussiemerc is offline
post #3 of 13 (permalink) Old 07-23-2019, 04:29 PM Thread Starter
Quoted: 2 Post(s)
Thanks, I'll see what I can find based upon that info.
post #4 of 13 (permalink) Old 07-23-2019, 04:35 PM
Quoted: 397 Post(s)
Smile Fuel pump assembly
Here's a pic that might help
Name:	107 Fuel pump assembly.jpg
post #5 of 13 (permalink) Old 07-23-2019, 04:38 PM Thread Starter
Quoted: 2 Post(s)
That's fabulous THanks. Those parts do not seem available, alas. I found everything else.
post #6 of 13 (permalink) Old 07-23-2019, 04:53 PM Thread Starter
Quoted: 2 Post(s)
Found on another thread based upon the info provided: t the valve is part number 116 470 0193 . NO longer in production.
post #7 of 13 (permalink) Old 07-25-2019, 06:23 PM Thread Starter
Quoted: 2 Post(s)
Hoping someone can provide the part number for the leak off line? Thanks
post #8 of 13 (permalink) Old 07-26-2019, 05:10 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Look up parts here: https://nemigaparts.com/cat_spares/epc/mercedes/
rowdie is offline
post #9 of 13 (permalink) Old 07-26-2019, 05:38 AM Thread Starter
Quoted: 2 Post(s)
Originally Posted by rowdie View Post
123 470 22 75
Wow thanks
SO this hose is available, just somehow separated from the 450sl parts connected to the fuel pump cluster.
https://www.pelicanparts.com/More_In...-470-22-75-MBZ
Also thanks to an internal search ECS tuning has both parts here's the valve
https://www.ecstuning.com/b-genuine-...-s/1164700193/
So thankful for all the help
For posterity:
1979 usa 450SL fuel accumulator cluster part leak off line / pressure compensating valve part number
post #10 of 13 (permalink) Old 07-26-2019, 07:02 AM
rowdie's Avatar
Quoted: 111 Post(s)
As usual Pelican Parts is too high. This forum sponsor (MB Dealer) is less. https://www.mboemparts.com/oem-parts...IFJlc3VsdHM%3D
Go to the supporting vendor forum. I think they have a code for shipping. Also try the valve number there.
rowdie is offline
