Coil Wire - I don't this is supposed to look like this. - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-28-2019, 08:50 AM Thread Starter
Walt Williams's Avatar
Date registered: Dec 2015
Vehicle: 1983 380SL (us), Former owner: 1965 190Dc
Quoted: 440 Post(s)
I have had a couple of occasions where my little gem wouldn't start. I could bump the top of the coil and it would start.
I decided to go out today and get this corrected. This is what I found. It appears that the coil wire connector has corroded itself into the coil. Now I have the task of removing the wire contact and getting it all cleaned up and a new wire fashioned.
I'm not sure why I didn't use the new coil wire when I replaced all the spark plug wires. I'm hoping its still around. I'm surprised this one got by me when I was doing the various bit maintenance when I first bought her.
The main this is I'm getting her fixed now before she strands me some where.
Walt Williams is offline
post #2 of 10 (permalink) Old 06-28-2019, 10:27 AM Thread Starter
Quoted: 440 Post(s)
It was pretty well frozen in there. I broke off the end trying to get it out. <damn>Then in an effort of getting the piece out of the coil I cracked the top of the coil.</damn>
I really didn't need this right now. but this will get the car back to being reliable.
https://www.partsgeek.com/catalog/19...tion_coil.html
https://www.partsgeek.com/catalog/19..._end_plug.html
post #3 of 10 (permalink) Old 06-28-2019, 10:39 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 679 Post(s)
I'd outright replace at that point. New Bosch coils are about $60 if I recall correctly.
And don't forget the new cable
okyoureabeast is offline
post #4 of 10 (permalink) Old 06-29-2019, 01:11 AM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
Unhappy Green wire
Be prepared for a $ shock .
Aussiemerc is offline
post #5 of 10 (permalink) Old 06-29-2019, 06:12 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
Avoid the URO green wire if you can, they have a known problem with intermittent connections at the dizzy.
Nobody gets out of this life alive.
Jyuma is offline
post #6 of 10 (permalink) Old 06-29-2019, 06:53 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
When did the infamous green wire enter into the OP's problem? Coil and coil cable/wire are the only things I see.
Walt Williams likes this.
rowdie is offline
post #7 of 10 (permalink) Old 06-29-2019, 08:53 AM Thread Starter
Quoted: 440 Post(s)
I've ordered a new Bosch coil and coil wire ends. I picked up a piece of solid core spark plug wire from my local part store this morning to make a new coil wire with. ($2 and change)
I have found with my Chevrolets that dispensing with the resistor wire on the coil wire and going with solid core increased the performance and made for a smoother running engine.
post #8 of 10 (permalink) Old 06-29-2019, 04:05 PM
Quoted: 397 Post(s)
Exclamation Infamous stupidity
My stupid contribution- sorry- wrong wire!
post #9 of 10 (permalink) Old 06-29-2019, 08:10 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 877 Post(s)
This is exactly what dielectric compound will prevent. Put it on all the dizzy connects and in the plug boots.
PanzerPuff is offline
post #10 of 10 (permalink) Old 06-30-2019, 07:38 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 118 Post(s)
+1 to PanzerPuff, amen!
miko1aj is offline
