Version II HVAC problem - Page 2 - Mercedes-Benz Forum
post #11 of 24 (permalink) Old 06-27-2019, 01:40 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 676 Post(s)
@gli48 , strangely enough you might be able to "fix" the faulty switch.
I had a switch go bad on an older 300D for the sunroof. Oxidation took a tool on the little arms that live inside.
I broke it down, cleaned it, and put it back together. The little guy worked.
I'd give this a shot if you can. Worst case scenario, you have to source a new one.
okyoureabeast is online now
post #12 of 24 (permalink) Old 06-27-2019, 03:40 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 397 Post(s)
Smile Fan Speed switch- old lever system.
This is my RHD (ROTW) fascia with lever mechanism.
The left knob is the speed control.
I'll see if I can find the invoice for the new switch I bought.
Name:	107  fascia.jpg
Aussiemerc is offline
post #13 of 24 (permalink) Old 06-27-2019, 10:46 PM
Quoted: 397 Post(s)
Checked with MB here--NLA
post #14 of 24 (permalink) Old 06-28-2019, 05:35 AM Thread Starter
gli48's Avatar
Date registered: Mar 2014
Vehicle: 1979 280 SL 4-speed, 2015 GLK 350 4-MATIC, 2012 Honda Accord Coupe V6 6-speed
Quoted: 12 Post(s)
Rowdie's post #10 is exactly what I have, Aussiemerc's picture is the same except for the headlight adjustment switch, which in my car is next to the light switch on the left side of the lower dash. Oddly enough, my console panel has cut out on the back matching the location of his headlight adjustment switch. Must be something like same part for LH & RH drive.
Okyoureabeast, I may have to resort to repair but the problem is the switch is riveted together so it may be a challenge to reassemble it. Id prefer to replace it, we'll see.
gli48 is offline
post #15 of 24 (permalink) Old 06-29-2019, 08:27 AM Thread Starter
gli48's Avatar
Quoted: 12 Post(s)
Well, the dealer is still searching all their sources, will let me know by Monday afternoon. The owner of the dealership has an extensive collection of old Benzes that they maintain so they're used to searching for obsolete parts. Pelican Parts first shows it as genuine MB at $157.95, then flips over to NLA. Adsit has a used one for $350 with a 60 day exchange warrantee, but if they're that hard to find what do I exchange it for? I may start disassembly but the problem is how to hold it together if I can fix it. It's held together with 4, 1 1/4" (3cm) long, thin rivets. Not sure how to duplicate that.
gli48 is offline
post #16 of 24 (permalink) Old 06-29-2019, 09:49 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Replace the rivets with long machine screws and nuts. I remember someone doing it with the dash light dimmer rheostat.
rowdie is offline
post #17 of 24 (permalink) Old 06-29-2019, 01:34 PM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
That would be me... #2 machine screw and nut are a perfect replacement for the long thin rivet. Just need the right length.
Nobody gets out of this life alive.
Jyuma is offline
post #18 of 24 (permalink) Old 06-29-2019, 03:06 PM Thread Starter
gli48's Avatar
Quoted: 12 Post(s)
Well I've got it apart, and found dirty contacts and the brass rotary contact was not making contact with the brass pads for speeds 3 & 4. Bent it slightly and it appears to work. Now the challenge is to put it back together. It looks like there is only room for a 3/32" hole at the largest without weakening the old Bakelite-like plastic. May be a challenge to find screws that small and long, we'll see.
gli48 is offline
post #19 of 24 (permalink) Old 06-29-2019, 04:01 PM
Quoted: 397 Post(s)
Maybe glue? It's probably ABS "plastic" and there are glues that work.
post #20 of 24 (permalink) Old 06-30-2019, 05:59 AM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 376 Post(s)
True Value Hardware has a very nice SAE and Metric selection for problems like this. Don't know if they are in South Central Michigan.
cushjbc is offline
