How many nuts on the brake booster? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-24-2019, 06:14 PM Thread Starter
Date registered: Sep 2015
Vehicle: 1976 450SL
Quoted: 72 Post(s)
I'm trying to remove the brake booster from my '76 450SL
I have removed the three visible nuts...but the booster still seems pretty firmly attached.
The fourth stud doesn't appear to be accessible, and according to this link at FCP only three of the four studs will have nuts on.
At this point I'm not sure if the booster is just 'stuck' to the firewall (and can be moved with a quick poke with the pry bar!), or whether there's another nut on there...don't want to damage anything, so thought I'd ask...
Update: Answering my own question. There are 4 nuts on there. The fourth one is buried behind the cruise control amplifier. Note to self: Should have replace the brake booster while the dash was out....
-Steve
'76 450SL 'Yard Find' Project
TheFixer is offline
post #2 of 4 (permalink) Old 06-25-2019, 04:46 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2348 Post(s)
Sounds like you found the answer. I recall using long extensions for some and smaller up close tools for others.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 4 (permalink) Old 06-25-2019, 04:55 AM Thread Starter
Vehicle: 1976 450SL
Quoted: 72 Post(s)
[QUOTE=Fonzi;17823858]Sounds like you found the answer. I recall using long extensions for some and smaller up close tools for others.
Three of the four nuts are easy (if you ignore the lying on your back in a 85'F garage part of 'easy') - regular gearwrench or open ended freed them up, and then you can spin them off by hand.
The fourth is a b****h to get at. I removed the 10mm holding the cruise amplifier in place, and dropped that down with the bracket, then used a long extension. Not looking forward to putting it back...
Hope this info helps someone. My guess is that the car FCP described in the link above had the booster replaced in the past, and someone just didn't bother putting the 4th nut back on...I can see why.
-Steve
TheFixer is offline
post #4 of 4 (permalink) Old 06-25-2019, 05:54 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
I could not get that one back on. Later someone posted it could be accessed by pulling a grommet on the firewall. I think this is it.
Fonzi likes this.
rowdie is offline
