E-brake light intermittent ... - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-20-2019, 06:58 AM Thread Starter
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1743 Post(s)
The red E-brake light on the instrument cluster is acting intermittently.
I look at the EPC but it does not show an electrical connection to the
E-brake pedal mechanism. How is this wired?
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #2 of 7 (permalink) Old 06-20-2019, 08:20 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
The switch is in another section. Electrical equipment........Main cable harness. PN 001 545 02 11
rowdie is offline
post #3 of 7 (permalink) Old 06-20-2019, 08:46 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Before we start an adventure on hacking the e brake apart, pull the cluster first and turn the bulb socket. Sometimes the copper gets warn down on a specific point, causing an intermittent connection.
I've had this happen on turn signal bulbs a lot. Odd to see it happen here!
okyoureabeast is online now
post #4 of 7 (permalink) Old 06-20-2019, 08:51 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Which is easier? Pulling the instrument cluster and checking the sockets or pulling off the wires on the e brake switch and jumping them together? I go for the switch first.
roncallo is offline
post #5 of 7 (permalink) Old 06-20-2019, 09:42 AM
Vehicle: 1984 380SL
Quoted: 638 Post(s)
I'll be honest RC, i've never done that, but I can pull the cluster in under 5 minutes flat if I have all of my tools in front of me.
Where's the switch at?
post #6 of 7 (permalink) Old 06-20-2019, 01:30 PM Thread Starter
cwmoser's Avatar
Rowdie, found it - you the man, you always come through answering anything R107. Thanks much.
Did a cursory look for the switch at the E-brake - looks like I'll have to disassembly some HVAC duct work.
BTW, was thinking about the Instrument Cluster as someone mentioned.
When I turn the ignition switch to the 3rd position, all the lamps illuminate except the Brake Light. No matter if I have the E-brake engaged or not.
Can someone verify that the Brake light should be illuminated like this when the E-brake is not engaged?
Carl
cwmoser is offline
post #7 of 7 (permalink) Old 06-20-2019, 04:53 PM
roncallo's Avatar
Quoted: 297 Post(s)
Its attached to the e-brake pedal mount. I can bend over and disconnect it and jump the wires in 3 minutes if I have the tools and a jumper wire in front of me.
When I was your age I would do it in 30sec.
Today bending over takes 1 min, straightening out takes another min.
cwmoser and okyoureabeast like this.
roncallo is offline
