Turn signal click sound resolved - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-19-2019, 05:41 PM Thread Starter
Martinp's Avatar
Date registered: May 2016
Vehicle: 1988 560SL
Quoted: 6 Post(s)
After ready a lot of post on this site I decided to replace the flasher relay to see if this would repair the lack of audible click noise since I had nearly nothing at all which most have either complained about or praised depending on where your at on this issue. I purchased KAE 3.101.200 Flasher relay tore into dash from underside and felt around back side to right of speedometer from behind and found it by touch. Long story is it worked and now the sound is back, also it might be my imagination but it also seems to have brightened the indicators also? Or itís just an illusion from being upside down under the dash for way too long. Anyway hope this helps those of you whom are bothered by this little detail or maybe not. Good luck anyway.
Martinp is offline
post #2 of 3 (permalink) Old 06-19-2019, 05:42 PM Thread Starter
Martinp's Avatar
Vehicle: 1988 560SL
Quoted: 6 Post(s)
Speed check terrible, maybe my eyesight and not my hearing thatís bad
Martinp is offline
post #3 of 3 (permalink) Old 06-19-2019, 07:30 PM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 744 Post(s)
Premium Member
My blinker makes no sound... but it wouldn't matter if it did... I can't hear shiot anymore anyway.
Aussiemerc likes this.
Nobody gets out of this life alive.
Jyuma is offline
