Help stray vacuum line - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-17-2019, 06:29 PM Thread Starter
Date registered: Jun 2019
Vehicle: In process of looking
Considering buying this 1987 SL, 63,000 miles. Runs great, shifts great, overall pretty clean condition.
Does have a minor idle shake, not severe enough to bother tach or be a problem when shifting into gear or out of gear, or coming to a breaking stop. Found this stray vacuum line under air cleaner, passenger rear corner of cleaner. I suspect this could be the issue. Not my car yet so I don't want to pull the air cleaner. Can anyone tell where the plugs into? See picture attached.
Thanks
Carlover76 is offline
post #2 of 6 (permalink) Old 06-17-2019, 06:43 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
That hose connects to the big black hose on the air cleaner. It's part of a safety system designed to shuttle leaking gas from the KEJet system diapragms into the engine where it's safely burned.
If you remove the air cleaner, you'll find a connection bit on the back of the side to stick him into.
okyoureabeast is online now
post #3 of 6 (permalink) Old 06-17-2019, 06:53 PM Thread Starter
Thanks for the tip. Will check out in the AM. Hope this caused the slight rough idle.
post #4 of 6 (permalink) Old 06-17-2019, 07:00 PM Thread Starter
okyoureabeast,
One more question...Does that mean there may be liquid gas leaking out of this plastic line? Or is it just vapors? In any event, is it dangerous to run with it not connected. ie fire hazard??
thanks
post #5 of 6 (permalink) Old 06-17-2019, 07:44 PM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 841 Post(s)
Here's a pic of the hose beast was talking about
In all honesty I don't think that that one line would cause what you are experiencing. Be prepared to find more leaks...that's part of the SL game. Do a search for "Italian Tune-up" should you buy the car. A long spirited drive cures many problems.
reno4u2 is online now
post #6 of 6 (permalink) Old 06-17-2019, 10:02 PM
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Originally Posted by Carlover76 View Post
okyoureabeast,
thanks
No it's a safety precaution in case they do leak. Which they rarely do.
And it won't be the cause of your rough idle.
