Automatic transmission in 350SL 1971 ? - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 06-17-2019, 12:45 PM Thread Starter
Date registered: Apr 2017
Vehicle: 1971 350SL
Quoted: 4 Post(s)
Hello,
I have a 1971 350SL with auto box. As I drive I can feel only 3 forward gears and one reverse gear... Is this normal? Or am I missing final forward gear? The revs get quite high when driving on a motorway...
Best regards, J
jarni75 is offline
post #2 of 19 (permalink) Old 06-17-2019, 01:09 PM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2345 Post(s)
I think you should have a 3.46 rear end. So high revs should be normal. I think 4 speed transmissions were installed on early 350sl cars, but later models got 3 speeds I think. So even if your car came with a 4 speed, it is possible if could have been replaced with a 3-speed, like one out of a 450sl (which had a 3.07 or lower rear end).
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 19 (permalink) Old 06-17-2019, 01:56 PM Thread Starter
Vehicle: 1971 350SL
Quoted: 4 Post(s)
How do I know which rear end do I have? My 107 was imported from USA 25 years ago... and I live in Europe... my final forward gear engages when I go past 60km/h... i do not care that much about acceleration - for me it is a matter of easy cruising with normal rpm and not high revving monster...
Does anyone know at what speed each gear engages? For 3 and for 4 speed auto box? So that I could compare what do I have installed....
Thanks for helping on this, J
jarni75 is offline
post #4 of 19 (permalink) Old 06-17-2019, 02:06 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
If a US model it may have a 350SL badge but it is a 450SL. It will have a 3 speed auto. Does the VIN begin 107.044?
rowdie is offline
post #5 of 19 (permalink) Old 06-17-2019, 02:13 PM Thread Starter
Vehicle: 1971 350SL
Quoted: 4 Post(s)
107.043... what does that mean? Earlier than 107.44?
jarni75 is offline
post #6 of 19 (permalink) Old 06-17-2019, 02:27 PM
rowdie's Avatar
Quoted: 109 Post(s)
107.043 is a 350SL which was not originally sold in the US. Apparently it was imported to the US then exported back.
rowdie is offline
post #7 of 19 (permalink) Old 06-17-2019, 02:38 PM Thread Starter
Vehicle: 1971 350SL
Quoted: 4 Post(s)
That is quite possible... Does anyone have any data on rpm vs mph speed ? So that I coul compare with mine...
Thanks, J
jarni75 is offline
post #8 of 19 (permalink) Old 06-17-2019, 08:54 PM
macarbon_john's Avatar
Date registered: Nov 2008
Vehicle: 72 350SL, 72 350 Euro, '83 500SL
Quoted: 23 Post(s)
VIN# will tell all
As the guys were asking, what is the full VIN? If its a really early 3.5L car, then it might have a 4speed auto. But things quickly changed to a 3 speed auto like the 4.5L cars. The 4.5L cars only had 3 speeds. Anyone know exactly which VIN Merc dropped the 4 speed on the 043 cars? Its somewhere between VIN#s 1100 and 1400. When I get home I'll see if I can read the German in one of my books to figure out when. I;d like to try driving one of the early 3.5L.
But my guess is the jarni75 has an early 4.5L car.
macarbon_john is offline
post #9 of 19 (permalink) Old 06-17-2019, 11:43 PM Thread Starter
Vehicle: 1971 350SL
Quoted: 4 Post(s)
My last 4 VIN digits are 3974... is there any sort of writing on the rear diff? So that I could know which is it?
Best regards, J
jarni75 is offline
post #10 of 19 (permalink) Old 06-18-2019, 12:06 AM
Quoted: 23 Post(s)
So at 3974 (you still don't say if its a 043 or 044), your car is certainly a 3 speed. So the car is likely performing as designed. I've never heard of there being different rear diffs - at least on either the 350 or 450. If you want a 4speed you have to get one of the super early 350s or get a later car. Anyway, pretty sure you are stuck with what you have.
