Window Scrappers/Seals - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-16-2019, 04:43 PM Thread Starter
RobbyH's Avatar
Date registered: Jul 2015
Vehicle: 1975 450sl
Quoted: 20 Post(s)
Hey guys,
Was just curious if anybody knew of a source for the inside and outside window scrappers/seals. I've only seen the sl shop and was just curious if there were any other options?
-RH
RobbyH is offline
post #2 of 6 (permalink) Old 06-18-2019, 10:17 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Mboemparts.com has them for a lot more. I recently bought the SL shop ones.
They're not bad, but they will need to be cut to size for the convertibles. The outer scraper is only for the slc models. The door seal ironically acts as the scraper .
RobbyH likes this.
okyoureabeast is online now
post #3 of 6 (permalink) Old 06-18-2019, 11:01 AM
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 158 Post(s)
I bought the inners from SLS-HH and the outers from the SLshop.
RobbyH likes this.
RaceDiagnostics is offline
post #4 of 6 (permalink) Old 06-18-2019, 06:53 PM Thread Starter
RobbyH's Avatar
Vehicle: 1975 450sl
Quoted: 20 Post(s)
Just curious, does anyone know off the top of their head if the doors differ from the SL to the SLC? Or in otherwards would the seals on the SLC fit the SL?
RobbyH is offline
post #5 of 6 (permalink) Old 06-18-2019, 11:32 PM
Vehicle: 1984 380SL
Quoted: 638 Post(s)
I can answer this!
The inner seal can be used on an SL but will need to be cut to size . The original SL seal has an L shape to it, but I've found it to be unnecessary. The SLC seal is slightly longer than the SL one.
The outer seal cannot. To do the outer seal you will have to replace the entire seal that goes around the door.
post #6 of 6 (permalink) Old 06-19-2019, 07:30 AM
Girota's Avatar
Date registered: Nov 2011
Vehicle: 1985 mercedes 500 sl,2011 E350
Quoted: 47 Post(s)
I have 20 pieces of brand new ones original mercedes,but not sure if I have only one side or set of left and right. Pm me Saturday if you want and I will check it out
Girota is offline
