500 SEC Engine Swap, High Idle; Where do I start? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-08-2019, 09:30 PM Thread Starter
Date registered: Oct 2014
Vehicle: 1981 380SL, 2012 GLK 350, 2008 Corvette, 2002 Nissan Xterra, 1965 Dodge Dart Wagon
Quoted: 38 Post(s)
Question 500 SEC Engine Swap, High Idle; Where do I start?
I swapped out my single row timing chain 380 engine for a 500 SEC engine and started it for the first time today. Played around with the timing and when it runs the best it idles at about 1500 RPM. What should I check first to find out why the idle is so high. I'll post a thread on the engine swap once I have it on the road.
Mirv is offline
post #2 of 10 (permalink) Old 06-08-2019, 11:40 PM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2348 Post(s)
The idle air valve has an electrical connection. When I unplug it, my idle goes to 1500 rpm.
Maybe try the idle air valve don your 380 motor and see what happens.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 10 (permalink) Old 06-09-2019, 07:41 PM Thread Starter
Quoted: 38 Post(s)
That didn't work but thanks for suggesting it.
Mirv is offline
post #4 of 10 (permalink) Old 06-09-2019, 11:48 PM
Date registered: Jan 2019
Vehicle: yet to be determined
Quoted: 40 Post(s)
a vacume leak will do the same thing depending on how bad it is..check everything and if you dont find anything you can start spraying the leak possible areas with carb cleaner..depending on the type the idle will go up or down when you get close to a spot
sh0rtlife is offline
post #5 of 10 (permalink) Old 06-10-2019, 05:36 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2390 Post(s)
Vacuum leak or "false air".
You can also use a plumber's torch (don't light it!!!) and see if the propane increases the idle.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #6 of 10 (permalink) Old 06-10-2019, 06:47 PM
Fonzi's Avatar
Does disconnecting the wire to the idle control valve do ANYTHING to the idle speed? If not, I wonder if you have a wide open idle control valve.
If it sounds like the idle control valve is not doing its job, then hereís a thread I recently started to try and track down how the idle control valve works. The YouTube video in the thread is very helpful in my opinion.
https://www.benzworld.org/forums/r-c...topics/3028292
My signature:
Fonzi is offline
post #7 of 10 (permalink) Old 06-10-2019, 10:39 PM Thread Starter
Quoted: 38 Post(s)
I have both so I will check it this weekend. Wish I had access to a smoke machine. I will also study the videos Fonzi posted about. It runs and runs smooth so I'm happy about that. I'm confident that I can get the idle sorted out before the SoCal GTG.
Mirv is offline
post #8 of 10 (permalink) Old 06-10-2019, 10:41 PM Thread Starter
Quoted: 38 Post(s)
I watched the one you posted and will watch the others. I'm sure I will find the problem. Thanks!!!
Mirv is offline
post #9 of 10 (permalink) Old 06-15-2019, 04:38 PM Thread Starter
Quoted: 38 Post(s)
Got out a can of carb cleaner to check for leaks. Found I had a cracked, leaking check valve. I checked voltage at the Idle control valve while running and get 3.7 volts. Adjusted the timing and idle is now around 900. I can live with that. Now I just have to finish buttoning it up and I'll be ready to take it for a ride tomorrow.
Fonzi likes this.
Mirv is offline
post #10 of 10 (permalink) Old 06-15-2019, 09:02 PM
therling's Avatar
Date registered: Dec 2011
Vehicle: 1987 560SL, 2000 Kawasaki W650
Quoted: 51 Post(s)
Ah, yes. Welcome to High Idle Hell. I was there for a while back in 2012 but I finally fixed it.
If you do a google search for "high idle hell" with the quotation marks it'll find a number of forum posts with that exact title.
https://www.benzworld.org/forums/r-c...le-causes.html
High Idle Hell - PeachParts Mercedes-Benz Forum
And even some entries with that title on YouTube:
Good luck. At some point you will find a way out of High Idle Hell, a place where many have dwelt and there is plenty of information from others who've escaped.
Tom
therling is offline
