Valve Clearence Question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-25-2019, 10:02 AM Thread Starter
Date registered: Oct 2014
Vehicle: 1981 380SL, 2012 GLK 350, 2008 Corvette, 2002 Nissan Xterra, 1965 Dodge Dart Wagon
Quoted: 39 Post(s)
Question Valve Clearence Question
What is an acceptable clearance for the valves? I had my cams ground and replaced the rocker arms and when I check the clearance with the go no go gauge, the bottom of the notch on the gauge lines up directly with the top of the tool. Is this acceptable or do I have to replace the compensation elements?
Mirv is offline
post #2 of 4 (permalink) Old 05-26-2019, 04:42 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
If you're talking about an early 380sl (81, 82) there is no clearance... only preload. If the bottom of the notch is even with the top of the gauge (insufficient preload) then it would appear you need a thicker Thrust Washer. They are sized in .35mm increments so take the Thrust Washer out and measure it's thickness (at it's smallest point) then order the next larger size. Their price at $20+ bucks a piece will make you weep.
Good luck.
Nobody gets out of this life alive.
Jyuma is offline
post #3 of 4 (permalink) Old 05-26-2019, 12:16 PM Thread Starter
Quoted: 39 Post(s)
Good luck.
I'm swapping out my single row timing chain engine for a 117, out of an 85 500SEC. I've never worked on this type of valve train so this is all new to me. I priced them at Autohaus AZ. Around $22.00 each. Ouch! I'll see if I can get a better price at my dealer.
Mirv is offline
post #4 of 4 (permalink) Old 05-26-2019, 02:47 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Size may matter but Look in the Supporting Vendor section of the forum. This one offers a code for shipping and $18.50 price on at least one size. https://www.mboemparts.com/oem-parts...her-1170530053
rowdie is offline
