Solved my high idle hell after 2 years! Solution info here with pic. 84 380SL - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-20-2019, 05:25 PM Thread Starter
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 15 Post(s)
I practically changed everything from gas tank to engine including new idle computer, still had same symptoms: High idle, erratic idle, hard start when hot, low performance. While checking for vacuum lines I noticed when I moved the fuel cooler around my idle jumped from 500s to 2500s, chaotically. Just like while driving. First I though maybe a vacuum leak. But it turned out to be ELECTRICAL! The bracket that carries the fuel cooler, and the ignition coil, is used to ground two brown wires to the chassis. I'm sure they are leading to some sort of temperature and idle control sensors. People in the know can chime in. I checked the ground connectivity here and it was on and off based on pulling and pushing the bracket. So I removed the bracket, sanded back and cleaned the chassis contacts. Mounted it back with new bolts and washers and now I have a totally different car. It's rock solid at 500s, started like a champ when hot, and drove like a beast. If you have high idle, erratic idle, etc you should check and clean this connection before throwing bunch of time and money at it, like I have for the past two years.
Name:	High idle issue solution.jpg
dr_b is offline
post #2 of 5 (permalink) Old 05-20-2019, 07:09 PM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 79 Post(s)
Good work. Bad grounds can cause strange things with these cars. Thanks for sharing.
Franklyspeaking is offline
post #3 of 5 (permalink) Old 05-20-2019, 07:35 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Thanks for posting this. These kinds of thing can drive you crazy.
roncallo is offline
post #4 of 5 (permalink) Old 05-20-2019, 08:03 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 859 Post(s)
outstanding info, will check for corrosion around grounds next time I'm out there!
PanzerPuff is offline
post #5 of 5 (permalink) Old 05-21-2019, 03:15 PM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 104 Post(s)
Glad you got sorted dr b, and thanks for spreading tje knowledge - threads like this one are the salt of this forum, sure as hell you've saved some other people a headache 👍😊
miko1aj is offline
Great diagnostic videos on high idle hell Rhinoww R/C107 SL/SLC Class 0 05-29-2017 06:58 AM
85 380SL high idle - steps completed - help on electrical test picture this R/C107 SL/SLC Class 6 10-06-2015 01:34 AM
1981 380sl High Idle Jim Reed Motors R/C107 SL/SLC Class 1 07-09-2013 09:43 PM
another variation of high idle rkar R/C107 SL/SLC Class 4 05-28-2010 09:00 AM
test Jillian80 Test 5 06-09-2008 11:28 AM
