My fan is alwasy screaming - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-20-2019, 02:20 PM Thread Starter
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 711 Post(s)
Premium Member
The fan is new but right from the start, hot of cold it does not matter, the fan is screaming... so much so that even with the top down at highway speed I can hear the fan.
My temp gauge sits between 90c and 95C, but even when I first start the engine the fan is screaming as I pull away in 1st and the engine goes over 2000 rpm. Shouldn't the thermal clutch disengage the fan unless the temp goes too high and it needs to cool down? I can't imagine the fan needs to do much work at 60mph on the highway but I can still hear it screaming.
Nobody gets out of this life alive.
Jyuma is offline
post #2 of 15 (permalink) Old 05-21-2019, 12:40 AM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 383 Post(s)
Definitely the fan and not a belt?
Aussiemerc is offline
post #3 of 15 (permalink) Old 05-21-2019, 03:19 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
Definitely the fan... everything up front is new except the AC compressor and that's not engaged.
Jyuma is offline
post #4 of 15 (permalink) Old 05-21-2019, 05:43 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 295 Post(s)
After I installed a new clutch I took a look at the old one. The fins were completely filled with debris including the sensor strip. No wonder it couldn't clutch out. Take a look at yours, maybe a little work with wire brush will revivify it.
Weather Man is offline
post #5 of 15 (permalink) Old 05-21-2019, 08:45 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Screaming or roaring? Try spinning cold. Should spin pretty easy but not freewheel.
rowdie is offline
post #6 of 15 (permalink) Old 05-21-2019, 08:47 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
It's brand spanking new... less than 2000 miles on it.
Besides... it screams at full speed as soon as I start the engine. Shouldn't the clutch engage as a function of heat?
Jyuma is offline
post #7 of 15 (permalink) Old 05-21-2019, 08:53 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
Roaring.
I'll spin it when I get home. I left it in the garage today... yesterday was 85 and sunny, when I left for work this morning it was in the 50's and windy. Go figure.
Jyuma is offline
post #8 of 15 (permalink) Old 05-21-2019, 03:03 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
I can move the fan blades but they don't spin free. When flipping the fan as hard as I can it comes to a dead stop as soon as I let go. There is no free spinning at all.
Is that good or bad... or is it a meaningless test?
Jyuma is offline
post #9 of 15 (permalink) Old 05-21-2019, 06:27 PM
rowdie's Avatar
Quoted: 106 Post(s)
I think it is bad. I tried my 560 and it advances 3 to five blades after I let go. I remember a test involving running engine and rolled up newspaper. I never had the guts to try it.
rowdie is offline
post #10 of 15 (permalink) Old 05-21-2019, 06:55 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
Mine definitely does not advance at all once I let go. I think I'll put the old fan clutch back on and see if it makes a difference.
Jyuma is offline
W126 86 560 SEC a/c and aux fan problems Jamesmontgomery W126 S,SE,SEC,SEL,SD,SDL Class 14 08-18-2017 02:22 PM
Fan Clutch Replacement RM98SL R129 SL-Class 49 12-07-2015 03:53 AM
tiny fan next to main blower fan is squealing! rschleicher W126 S,SE,SEC,SEL,SD,SDL Class 13 03-20-2014 10:40 AM
Successful DIY Notes for the list: Radiator, Fan Clutch, Temp Sensors, Fuel Pump ericgr R/C107 SL/SLC Class 8 02-18-2010 02:03 PM
Fan Clutch Fiasco - What to do next?? bjflatley R129 SL-Class 12 07-06-2009 07:11 PM
