560 SL - Rocker Arm - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 05-20-2019, 08:00 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 87 Post(s)
560 SL - Rocker Arm
Hello,
I am hearing a slight ticking sound coming from one of the rocker arms, can the hydro rocker adjuster (see attached picture) be adjusted to reduce any slack?
Sent from my MAR-LX1M using Tapatalk
R107
S320L1999 is offline
post #2 of 14 (permalink) Old 05-20-2019, 08:41 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 711 Post(s)
Premium Member
The valve clearance is adjusted by changing the thrust washer thickness. They come in various thicknesses. There is a tool you use to check the adjustment and then you select the thrust washer thickness to bring the clearance (actually pre-load) into spec.
The picture shows the thrust washer, the rocker is also likely the same on your engine but the other components shown in the photo probably don't apply to your car.
Nobody gets out of this life alive.
Jyuma is offline
post #3 of 14 (permalink) Old 05-20-2019, 08:43 AM Thread Starter
Vehicle: W107 W113
Quoted: 87 Post(s)
Thank you - so the "adjuster" isn't used for adjustment?
R107
post #4 of 14 (permalink) Old 05-20-2019, 09:19 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
It is on those. They are for solid lifters.
rowdie is offline
post #5 of 14 (permalink) Old 05-20-2019, 10:42 AM Thread Starter
Vehicle: W107 W113
Quoted: 87 Post(s)
The 560 SL has solid lifters?
R107
post #6 of 14 (permalink) Old 05-20-2019, 10:55 AM
rowdie's Avatar
Quoted: 106 Post(s)
No. I have no idea why the picture showed 560 in the title. Only the early 3.5, 4.5 and all M110 2.8 107s had solids.
rowdie is offline
post #7 of 14 (permalink) Old 05-20-2019, 10:56 AM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 108 Post(s)
The "thrust washer" in Jyuma's pic is available in various thickness to shim the hydraulic compensator you posted.
isthisdave is offline
post #8 of 14 (permalink) Old 05-20-2019, 10:57 AM Thread Starter
Vehicle: W107 W113
Quoted: 87 Post(s)
My car is a 560 SL - this part showed on the diagram, obviously wrong then.
How is a ticking sound then remedied, new lifter or new arm?
R107
post #9 of 14 (permalink) Old 05-20-2019, 12:57 PM
Premium Member
Jyuma's Avatar
Quoted: 711 Post(s)
Premium Member
I think we better clear a few things up before we go too far into left field.
1. The picture you originally posted is a hydraulic compensator... it is not adjustable.
2. The picture I posted was to show you what a thrust washer looks like. The other components in the picture I posted can be ignored, as they are not for your engine (the rocker may be).
If I'm understanding correctly your engine uses hydraulic compensators (like the one you posted in your picture), which screws directly into the head (no adjustment). The hydraulic compensator provide a pivot point for the rocker that sits between the cam and the top of the valve. Perched on the top of each valve is a thrust washer (shown in the picture I posted). The thrust washers come in a variety of thicknesses... and they ain't cheap.
https://www.autohausaz.com/catalog/k...adjuter%20shim
You need a special tool to measure the preload. The tool will tell you if you need to use a thicker shim or a thinner shim or it's right the way it is. Search the forum, there are a number of threads on the use of the special tool.
Here's a picture of the tool.
Here's a diagram showing the tool mounted in position for measuring.
FYI... I have a valve tick in my 380 and I replaced all the hydraulic compensators and adjusted all the Thrust Washers to dead nuts... and I still have the tick. Grrr.
Jyuma is offline
post #10 of 14 (permalink) Old 05-21-2019, 01:05 AM Thread Starter
Vehicle: W107 W113
Quoted: 87 Post(s)
Great, thank you.
So, the attached picture is in fact a hydraulic lifter.
So the possible solutions/reasons for the slack and resulting noise are:
1. Cam lobe
2. Rocker arm
3. Defective lifter
So the pucks/shims could compensate for worn rocker or lobe?
R107
560 SEC rocker arm failure kausi W126 S,SE,SEC,SEL,SD,SDL Class 14 09-10-2018 11:55 PM
Clicking sound from cylinder 3/4 Ruindr R/C107 SL/SLC Class 12 01-22-2016 03:36 AM
560 SEL rocker arm failure JessieAMorris W126 S,SE,SEC,SEL,SD,SDL Class 8 08-04-2015 12:57 AM
91 560 SEL $8200 SALT FREE UNMOLESTED ORIGINAL 82K MILES fabbrisd1 For Sale/Wanted/Trade/Giveaway 12 03-09-2015 11:04 AM
Swapping arm rest - installng arm rest with storage cubby alia176 W124 E,CE,D,TD Class 13 11-02-2012 10:11 PM
