Removing Smog Pump - trying to identify part where the hose connected to the block - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-19-2019, 07:24 PM Thread Starter
Date registered: Sep 2015
Vehicle: 1976 450SL
Quoted: 68 Post(s)
I spent today remove the under-hood catalytic converters and smog pump.
Having removed the smog pump, there's a small 'plate' just in front of the right hand exhaust manifold that is attached with 3 Allen (hex socket) bolts. This has the pipe to the (now gone) air pump on it, and also some kind of breather (?) - a very short cast metal pipe. I'm trying to find out if I can remove it (and if perhaps there's a blank plate to replace it).
There is a part number on it, but I can't find it in the EPC - but I think that's because I'm not reading the number correct.- it's a pretty rough casting.
Photo below shows the part (it is upside down though, so you can read the #) - I think it is A1170520251, but I've tried various variations on that.
Any one else who removed their smog pump - did you remove this as well? Did you find a replacement 'blank'?
-Steve
Name:	2019-05-19 21.55.44.jpg
'76 450SL 'Yard Find' Project
TheFixer is offline
post #2 of 4 (permalink) Old 05-20-2019, 03:39 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
That is the timing chain tensioner 117 050 10 11. Time to replace anyway. Have you changed the guides and chain? The raised number may be a casting number.
rowdie is offline
post #3 of 4 (permalink) Old 05-20-2019, 04:07 AM Thread Starter
Vehicle: 1976 450SL
Quoted: 68 Post(s)
Thanks! Tensioners were on the list for later, but now I see where they are I'll do them before putting this all back together!
Is there a part number for a cap to go over the air pump connector on the tensioner?
Sent from my SM-T813 using Tapatalk
TheFixer is offline
post #4 of 4 (permalink) Old 05-20-2019, 05:30 AM
rowdie's Avatar
Quoted: 106 Post(s)
EPC does show one.
rowdie is offline
Hose between block and water pump replacement litlquiver W126 S,SE,SEC,SEL,SD,SDL Class 4 05-06-2015 02:28 PM
SLS high pressure hose Real1shepherd W124 E,CE,D,TD Class 62 06-15-2014 10:42 AM
Successful DIY Notes for the list: Radiator, Fan Clutch, Temp Sensors, Fuel Pump ericgr R/C107 SL/SLC Class 8 02-18-2010 02:03 PM
I experienced the dreaded fouled fuel pump over the weekend CCORLEY W163 M-Class 14 03-21-2007 04:39 AM
US now admits it used chemical weapons against Iraqis FeelTheLove Off-Topic 139 11-23-2005 05:29 PM
