Fan Clutch - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-17-2019, 08:59 AM Thread Starter
longbeach1's Avatar
Date registered: Dec 2015
Vehicle: 2003 E320 4matic wagon; 1979 450 SL
Quoted: 39 Post(s)
Fan Clutch
So,on my 79 450 sl I'm wondering if fan clutch is working correctly. There is plenty of resistance when I spin it buy hand it only spins a blade or two. But,when I start the car cold,after about a minute or two the fan will pickup speed noticeably. Then after a minute or two of that it goes back to regular speed. While driving I never hear it speed up again,no matter the temp.....
longbeach1 is offline
post #2 of 7 (permalink) Old 05-17-2019, 09:33 AM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 33 Post(s)
your fan clutch is probably bad. although check your radiator with an ir temp gauge because on your car its probably original.
what temps does your car get up to?
it should be around 87 deg even in traffic although your car probably has farenheit temp gauge so just over 175
at normal temp I can hear mine roar when pulling away from traffic in like 70 deg weather
christuna is online now
post #3 of 7 (permalink) Old 05-17-2019, 09:57 AM Thread Starter
longbeach1's Avatar
Quoted: 39 Post(s)
Christuna,thanks for the reply. My car normally runs right around 175 when moving.But as soon as stop in traffic the temp starts to climb and will go to 212 and a little beyond. I just put a new auxiliary fan in and ran a manual switch so I can turn it on when I want. But, the way the fan clutch acts has me suspecting that is not working correctly. The aux. fan did not work at all so I needed to replace that anyway...
post #4 of 7 (permalink) Old 05-17-2019, 10:03 AM
Vehicle: 1990 300SE
Quoted: 33 Post(s)
that's exactly what mine did when my fan clutch failed. your radiator is most likely ok.
post #5 of 7 (permalink) Old 05-17-2019, 10:05 AM Thread Starter
longbeach1's Avatar
Quoted: 39 Post(s)
Christuna,thanks.Guess I'll order a fan clutch...
post #6 of 7 (permalink) Old 05-17-2019, 12:31 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
We have those Fan Clutches: https://www.autohausaz.com/catalog/c...tch?s=d&page=1
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #7 of 7 (permalink) Old 05-17-2019, 02:02 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 606 Post(s)
Totally off topic, but are you the guy that drives his r107 during the cherry festival?
okyoureabeast is offline
I may have messed up FAN CLUTCH? sparky1016 W163 M-Class 10 05-23-2017 04:10 PM
1994 E420 fan clutch redheadeight W124 E,CE,D,TD Class 11 07-12-2012 12:52 PM
Viscous Fan Clutch Pulley Loose dpaterso W140 S-Class 2 05-22-2012 05:08 PM
Viscous Fan Clutch Ears R/C107 SL/SLC Class 9 10-17-2010 02:16 PM
DIY checking and replacing the fan clutch Tedd300DT W202 C-Class 16 05-20-2009 10:49 PM
