1989 560SL Climate Control Unit Question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-15-2019, 12:22 PM Thread Starter
Date registered: Aug 2017
Vehicle: 1988, 560SL
Quoted: 43 Post(s)
Long ago, I removed the climate control unit and am now at the point to putting it back in. When I go the car, the climate control system didn't work so I have no idea if the push button switch unit works. On either side of the unit are pin connectors that are identical. In the dash are the two female connectors, one has a short wire bundle and the other is longer. I am not sure which connector goes where. Assume the short wire bundle one connected the location behind the fan push button and the longer wire bundle on connected behind the temperature wheel.
I have connected them both ways and nothing appears to work. To start this fun, I at least want to have the connectors in the right spots.
Anyone know of a thread that helps diagnose the system?
If I leave the small wire bundle unplugged and plug in the long one behind the temperature control, the defrost will come on when the button is pushed (fan on high, compressor engaged and is hot air, which I believe is how its supposed to be). When I plug the short on back, it shuts off the defrost.
I've checked the fan it works fine, thanks for any tips
Name:	climate control wiring.jpg
orbit398 is offline
post #2 of 3 (permalink) Old 05-15-2019, 12:36 PM
willyusa's Avatar
Date registered: Dec 2017
Vehicle: 1988 560SL - 79K miles
Quoted: 5 Post(s)
I was just in there myself this weekend... the short cabled one goes to the right side as you face it, so yes, the side that has the fan speeds selector.
willyusa is offline
post #3 of 3 (permalink) Old 05-15-2019, 03:11 PM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 77 Post(s)
x2. Been there so often, I have it memorized.
Franklyspeaking is online now
Got My MB STAR C4 Diagnostic Tool Today! ArcticDweller R129 SL-Class 1068 05-21-2019 08:57 AM
Bosch KE-Jetronic Overview isthisdave R/C107 SL/SLC Class 16 11-20-2012 03:33 PM
Naked Bodies and a New Messiah Green Groups Try to Sex Up Climate Change Teutone Off-Topic 1 01-03-2011 01:44 PM
ML NOT STARTING IN HOT WEATHER OR HOT ENGINE!!!!! jmarenas W163 M-Class 11 09-06-2005 03:42 PM
