Recirculation Rocker Switch Above Push Button Unit - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-13-2019, 07:59 PM Thread Starter
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 78 Post(s)
My 560sl switch appeared to be non-functional, in that the red light would not light when the switch was pushed. So I took it apart and put it back together wrong as it still did not work. Took it apart again and put it back together a different way and so now the red light comes on when you push the top part and then goes off when you push the red light. I checked and the vacuum flow through it does not seem to change (that I can tell). Can anyone tell me what happens with the three way branch A/B/C when the light is on and off. In other words with the red light off (default) is B and C connected? And when the red light is switched on A releases the vacuum? Or better yet what are the vent pods supposed to do?
I have always heard that the Germans can take something simple and turn it into something extremely complex. They must have been talking about the R107, AC IV.
cwmoser likes this.
Franklyspeaking is offline
post #2 of 3 (permalink) Old 05-14-2019, 09:43 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 575 Post(s)
When you press that button, the two fresh air flaps should push upwards and close off the cabin to the outside world.
You can observe this by removing either the instrument cluster or glove box and looking up. You'll see one of the fresh air flaps push upwards to close.
Not that complicated, just frustrating when it isn't working right
okyoureabeast is offline
post #3 of 3 (permalink) Old 05-14-2019, 01:35 PM Thread Starter
Quoted: 78 Post(s)
Thanks....I guess the circular diagram illustrates the airflow going in circles and the red light denotes that it is recirculating. I have the same picture in my C280, but never use it and didn't know what it meant. I think this means that the switch defaults to B and C vacuum lines dumping to the vent A. When the switch is activated it links B and C together and disconnects A while opening the vacuum solenoid on circuit 4.
2002 C320 ESP/BAS warning, but never had Stop Lamp Switch / Brake Light Switch. ant68 W203 C-Class 4 01-10-2015 06:05 AM
DIY for manually controlling center and footwell vents in a W124 zebellis W124 E,CE,D,TD Class 22 11-13-2014 04:46 PM
1994 1995 c class acc push button unit creynldsthree W202 C-Class 0 05-01-2012 04:31 PM
Ignition Switch New fits many models sammywater For Sale/Wanted/Trade/Giveaway 0 10-24-2010 04:49 PM
