560SL Loose Door Handle "Fix" - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-12-2019, 08:42 AM Thread Starter
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 838 Post(s)
The driver's side door handle (actually the handle frame) loosened up on my 560SL. Immediate thought was I had to pull the door card. Got to thinking about it and realized that years ago this had happened before. Also knew I had fixed it without removing the door card. Checked it out and there is a Phillips head screw that is partially hidden by the door seal/rubber. The fix...tighten the screw. Sometimes things are too easy...
Name:	DSCN3078 (Large).jpg
cwmoser and dak503 like this.
reno4u2 is offline
post #2 of 7 (permalink) Old 05-14-2019, 05:12 AM
ryson's Avatar
Date registered: Sep 2010
Vehicle: 1979 450SLC
Quoted: 9 Post(s)
Good to know. My door hand is a little loose and I was going to live with it since I had a better reason to pull the door apart. Will have to check now if this fixes my issue and avoid the wait.
ryson is offline
post #3 of 7 (permalink) Old 05-14-2019, 05:21 AM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1731 Post(s)
I'll admit, this posting did pique my interest.
Made me get up and go out to the Garage and see where that screw was.
Good information to know just in case my door handles get loose.
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #4 of 7 (permalink) Old 05-14-2019, 06:52 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
1985 and earlier models have two screws. They are not as easy to see.
cwmoser likes this.
rowdie is offline
post #5 of 7 (permalink) Old 05-14-2019, 10:14 AM
cwmoser's Avatar
Son of a Gun!!
This also made me get up, go to the garage, and check on my 1983 380SL.
There are two phillips screws.
Carl
cwmoser is offline
post #6 of 7 (permalink) Old 05-14-2019, 11:34 AM
rowdie's Avatar
Quoted: 106 Post(s)
Oops! Forgot the picture.
rowdie is offline
post #7 of 7 (permalink) Old 05-15-2019, 06:36 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2374 Post(s)
Hmmm.
Reno with a screw loose.
Who knew??
reno4u2 likes this.
Originally Posted by nobby View Post
Don’t’ ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
STORY: My 450sl couldn't keep up with a 560sl tonight Fonzi R/C107 SL/SLC Class 20 07-31-2011 09:16 PM
Another new 560SL member into the mix! SeattleSunshine R/C107 SL/SLC Class 7 07-08-2011 03:29 AM
450sl vs 560sl values, & my 560sl for sale hapaschold R/C107 SL/SLC Class 13 12-24-2010 05:56 AM
1988 560SL "M" in Grill is Loose S Dennis General Mercedes-Benz 2 06-18-2009 06:12 AM
Sloppy or Loose Steering problem check with fix. stinger R/C107 SL/SLC Class 1 02-08-2004 08:11 PM
