Whining/Groaning Power Steering Pump - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 05-09-2019, 07:18 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 219 Post(s)
I have a similar noise--more of a whine--that I think is coming from the PSP on my 74 450SL, but it goes away once the car is warmed up. Could this be the same thing?
rcrmonte3 is offline
post #12 of 15 (permalink) Old 05-10-2019, 01:40 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 116 Post(s)
pump
Just like my pump was .But after the removal of old fluid and filled with the right oil the noise as gone if its hot or cold .But do use the right PAS fluid lots of owners think its ATF fluid and its not .
This is a retro ride .
plinker17722 is online now
post #13 of 15 (permalink) Old 05-13-2019, 05:18 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
They think it should be ATF because that is what the owners manual states. I have looked manuals for '72, early '80s and an 86. As others have stated modern ATF may contain harmful additives.
rowdie is offline
post #14 of 15 (permalink) Old 05-13-2019, 10:12 PM
Ianwright40's Avatar
Date registered: Dec 2015
Vehicle: 1973 450SL, 1999 c230
Quoted: 319 Post(s)
If it whines and groans too much you have two choices.. 1 Replace it or 2 marry it.
I replaced the fluid in mine and it's quiet but it's also weeping out of the steering box.
Ianwright40 is offline
post #15 of 15 (permalink) Old 05-15-2019, 03:11 PM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 100 Post(s)
I've had similar experience after the car's been parked up for a few weeks, when I pulled out from the garage and turned the steering wheel I thought the PSP was on the way out. Went for a spin, and all was good afterwards - as okyourabeast noted those cars don't like stagnating, use it or lose it 🙂
miko1aj is online now
Pictorial: Steering Box R&R and Engine Mounts slownrusty W126 S,SE,SEC,SEL,SD,SDL Class 20 03-17-2019 06:43 PM
Air trapped in the Power Steering? or bad PS pump/rack? Need 43spd or Erik! ctravis595 W220 S-Class 3 01-05-2017 05:02 AM
DIY to remove and install ABC pump SpawnyWhippet R230 SL-Class 23 06-15-2016 01:59 PM
DIY Power Steering Pump replacement rajdude W251 R-Class 7 06-15-2014 07:12 PM
Power Steering Pump Replacement Starglider W220 S-Class 5 03-08-2007 06:07 AM
