Brake Issue - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 05-10-2019, 05:13 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2371 Post(s)
You have been offered some suggestions.
What HAVE YOU done so far?
Taken the wheel off and cleaned everything up?
Maybe that rotor is a little out of true?
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #12 of 12 (permalink) Old 05-10-2019, 09:20 AM Thread Starter
jrthe1's Avatar
Date registered: Jan 2014
Vehicle: 1988 560SL
I just posted yesterday, Nobby, so I haven't done much. The wheels were off recently and a mechanic looked over the brakes pronouncing them fine. Other than the problem I described the brakes work great....like butter.
My plan of action is to defeat the ABS system and then see if the problem goes away. If it does, and I think it will, the next step will be to clean the front ABS sensors. If that doesn't work, I dunno. I may just keep the ABS defeated as I do not want to sink a ton of time and money (mostly money) on ABS when the car is only driven in fair weather.
Thanks everyone for leading me in the right direction. If anyone has experienced my issue (1.loose pedal and that abs pulsating feeling and noise from the front brakes when stopping at slow speeds 0-20 mph. 2. ABS light does not come on when driving. ABS light works with key on.), please chime in.
jrthe1 is offline
w210 wagon third brake light replacement Diaster thejoebear W210 E-Class 2 05-20-2016 09:05 AM
2008 ML350 - Low Brake Pedal Issue mamin123 W164 M-Class 7 04-06-2016 05:27 PM
2001 E 320 4 matic... Brake light switch issue??? Mercedes1981 W210 E-Class 5 11-19-2013 06:56 AM
Brake issue 2000clk320silver C208/A208 CLK-Class 0 11-18-2013 02:11 PM
Brake lines? Clean with compressed air? bradsscooters R/C107 SL/SLC Class 20 04-22-2012 06:44 PM
