Rough cold start idle - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-04-2019, 10:26 PM Thread Starter
ryson's Avatar
Date registered: Sep 2010
Vehicle: 1979 450SLC
Quoted: 9 Post(s)
I've been reading posts and haven't found one yet that matches my exact situation. Had the car serviced recently and the car runs good when warm with an idle in the 750 rpm range. Plugs all changed and spark plug wires checked. But when doing a cold start in the AM, it starts up quick but the idle drops to 500 +/- and you can smell gas and the engine shakes bad. Warm up regulator? Car doesn't stall when I step on accelerator while it is still warming up.
ryson is offline
post #2 of 9 (permalink) Old 05-04-2019, 10:28 PM Thread Starter
ryson's Avatar
Quoted: 9 Post(s)
Forgot to mention I have a '79 450SLC. Previously the rpm was always high at 1000 rpm when in idle and it did not have the cold start issue.
ryson is offline
post #3 of 9 (permalink) Old 05-05-2019, 06:11 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2360 Post(s)
Check to see if you have 12V at the WUR harness.
Check and see if your Aux. Air Valve is stuck closed.
Sounds like your cold start valve is working.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #4 of 9 (permalink) Old 05-05-2019, 08:49 AM Thread Starter
ryson's Avatar
Quoted: 9 Post(s)
Thank Nobby.
For others, found this thread to assist.
https://www.benzworld.org/forums/r-c...topics/1600137
ryson is offline
post #5 of 9 (permalink) Old 05-10-2019, 05:09 AM
Bob's Your Uncle!
nobby's Avatar
Thank Nobby.
Don't go down that rabbit hole. He is explaining a D-Jet fuel delivery system.
YOU have a K-Jet.
nobby is offline
post #6 of 9 (permalink) Old 05-10-2019, 05:42 AM Thread Starter
ryson's Avatar
Quoted: 9 Post(s)
Thanks again.
Found this but still looking for one better describing mine. But this should.be closer.
https://www.benzworld.org/#/topics/2182425
ryson is offline
post #7 of 9 (permalink) Old 05-10-2019, 06:54 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 597 Post(s)
Thanks again.
Myndex is explaining how the frequency valve operates and the nightmare it takes to configure the kjet lambda system in spec.
The WUR is essentially an automatic choke that decreases the fuel pressure.
In the fuel Distributor, there's a spring loaded system pressure regulator. When the fuel pressure is higher, more fuel enters the system making it run rich.
As the WUR warms either by 12v or residual engine heat, the fuel pressure drops and the system regulator lets less fuel in. This leans the mixture out.
A failure of either the WUR, system pressure spring, and/or fuel Distributor diaphragm will make for a bad day.
Given the symptoms, I would suspect your WUR. However, these cars like to fool you and the only way to tell is with a fuel pressure test kit. I recommend you purchase one and start by checking the fuel pressure. Make sure it has kjet fittings!
This is done by hooking the test kit up between the WUR, the fuel Distributor fuel fees line, and taking readings at room temp, warm up, and full operating temp.
There are a few guides floating around here on how to do all of that.
Once you do all of that, we can move onto your lambda system next 😉
Good luck!
okyoureabeast is offline
post #8 of 9 (permalink) Old 05-10-2019, 11:40 AM Thread Starter
ryson's Avatar
Quoted: 9 Post(s)
Thanks for the explanation. That helps.
ryson is offline
post #9 of 9 (permalink) Old 05-18-2019, 11:58 AM Thread Starter
ryson's Avatar
Quoted: 9 Post(s)
As anticipated, it was the WUR. Replaced it and now every thing is running smooth.
ryson is offline
1975 350SL D-Jet Cold Start Injector Diagnostic GoldDragon R/C107 SL/SLC Class 6 04-04-2015 03:33 PM
Bosch KE-Jetronic Overview isthisdave R/C107 SL/SLC Class 16 11-20-2012 03:33 PM
Rough Idle or Misfire In Gear and Hard Start mannys9130 W201 190-Class 26 02-09-2012 10:35 AM
Cold High Idle, Hot Hard start issue MBBoo R/C107 SL/SLC Class 27 07-29-2009 12:45 PM
COld Start & stall after in gear & rough idle at stop rbartholomew W126 S,SE,SEC,SEL,SD,SDL Class 6 10-28-2006 01:30 AM
