'107 Fixit Squad Needed' - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 04-27-2019, 07:25 PM Thread Starter
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
Help Needed in Waukesha, WI area.
I am having back surgery May 6 and won't be able to work on my 107 for several months
The Red Roadster needs a small group to perform some repairs:
Rust hole in left inner fender
rear swaybar links
relay mounts above fusebox
replacement Hirschmann antenna installed (74 450SL)
Flexible fuel lines replaced
Any chassis problems found (not sure there are any)
turn signal switch installed.
Anything that doesn't get done will be worked on over the Winter.
Thank you.
Rudiger1960 likes this.
rcrmonte3 is offline
post #2 of 28 (permalink) Old 04-27-2019, 08:01 PM
joser85's Avatar
Date registered: Feb 2018
Vehicle: 1985 380sl
Quoted: 22 Post(s)
Damn, that's no fun. Good luck with the surgery!
joser85 is offline
post #3 of 28 (permalink) Old 04-27-2019, 09:55 PM Thread Starter
rcrmonte3's Avatar
Quoted: 222 Post(s)
Thanks, joser. It would be fun supervising a group and doing what I can.
post #4 of 28 (permalink) Old 04-27-2019, 10:27 PM
frazierfrazier's Avatar
Date registered: Aug 2009
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Sounds like fun, wish I was closer! Hope you make a “speedy” recovery.
frazierfrazier is offline
post #5 of 28 (permalink) Old 04-28-2019, 05:33 AM Thread Starter
rcrmonte3's Avatar
Quoted: 222 Post(s)
Thanks, ff.
post #6 of 28 (permalink) Old 04-28-2019, 06:34 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2360 Post(s)
rear swaybar links
Thank you.
Sounds like bullshit.
I'm having surgery, too. Can someone come cut my lawn?
OK, just kidding. I'm hoping it's bullshit.....but if not...good luck with the surgery and recovery.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #7 of 28 (permalink) Old 04-28-2019, 07:02 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 706 Post(s)
Premium Member
They have lawns in the frozen tundra?
Nobody gets out of this life alive.
Jyuma is offline
post #8 of 28 (permalink) Old 04-28-2019, 07:19 AM Thread Starter
rcrmonte3's Avatar
Quoted: 222 Post(s)
Thanks for the good wishes. Same to you.
No, nobby, it's not BS. Well, it is bs--Back Surgery. The surgeon says I'll be laid up most of the Summer and not able to bend and twist like needs to be done working on a car--especially a 107.
post #9 of 28 (permalink) Old 04-28-2019, 07:21 AM Thread Starter
rcrmonte3's Avatar
Quoted: 222 Post(s)
It's artificial turf--but don't tell Nobby. If he wants to cut it, it's up to him...
post #10 of 28 (permalink) Old 04-28-2019, 06:41 PM
Bob's Your Uncle!
nobby's Avatar
Nature's joke.
Hours of work pulling weeds, air rating, fertilizing, seeding and cutting....only for green lawn 5 months of the year. The rest of the time covered in snow and frozen solid.
And then start all over again.
nobby is offline
The Encyclopaedia Germanica Volume 107 (aka EGv107) Digmenow R/C107 SL/SLC Class 10 09-15-2013 10:43 AM
107 Rear Torsion Bar Bushings Needed euro500sl R/C107 SL/SLC Class 3 05-27-2012 05:40 AM
Door Speakers Ideas Needed For 107 euro500sl R/C107 SL/SLC Class 5 05-13-2012 06:49 AM
107 sparkplug wire covers/tubing needed euro500sl R/C107 SL/SLC Class 2 05-12-2012 06:57 AM
Corbeau GTS II seats for 107? Feedback needed euro500sl R/C107 SL/SLC Class 5 04-09-2012 05:06 AM
