Idle “hiccup” - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-20-2019, 11:35 AM Thread Starter
frazierfrazier's Avatar
Date registered: Aug 2009
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Idle “hiccup”
Can’t think of a better way to describe it, but when the car is idling at a stop, for a split second the revs will drop very slightly, and the rear end of the car will jump up just a hair. Very intermittent. Sometimes I notice this under heavy acceleration, but the effect is that when it “hiccups”, you lose a bit of power. It’s REALLY irritating, and I’ve had this issue since day one, presumably.
It idles just fine otherwise. Some days it runs perfectly, without a single one of these incidents, other days it will do it once or twice and some days it’s really noticeable.
Changed all the plug wires after I did the timing chain, and that seemed to help a little, but I’m sure it’s all in my head.
Injectors are original, around 80k miles on them. Dump Techron in every once and awhile and can’t say I notice a difference. Stumped!
frazierfrazier is offline
post #2 of 3 (permalink) Old 04-21-2019, 07:43 AM
Jack Rushing's Avatar
Date registered: Apr 2009
Vehicle: 1985 500SL. Previous cars-190SL, 230S, 250SE, (2) 300SDs
Quoted: 14 Post(s)
I have had this trouble. Found out it was a bad fuel injector.
frazierfrazier likes this.
Jack Rushing is offline
post #3 of 3 (permalink) Old 04-22-2019, 06:02 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 298 Post(s)
Yeah, when mine does that I know it is time to take it for a run at speed.
Weather Man is offline
M120.982 W140 EPC light, 4,000rpm revlimit in 1st, rough idle, plus codes. Joe-V12 W140 S-Class 180 11-19-2018 09:42 PM
B200 Turbo occasional rough idle almost always only after engine fully warmed up W245Wiggler W245 B-Class 7 06-22-2018 09:23 AM
1983 380SL High idle zoltar R/C107 SL/SLC Class 20 07-22-2012 09:55 AM
M103 Idle problem, I've done some digging... questions akimball442 W126 S,SE,SEC,SEL,SD,SDL Class 18 06-12-2008 06:29 PM
Does anyone know where is the location of the idle control unit joconab R/C107 SL/SLC Class 6 05-23-2008 06:34 AM
