Hard Top Removal Problem - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 04-16-2019, 07:19 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 298 Post(s)
Carl Moser discovered that gap on his 380. There I learned I also had a slight gap which sometimes caused problems. In my case I can just hold the small locking lever all the way to its stop with one hand while releasing the lock with the other. *POP*
Just a millimeter gap will cause it to stick. So if you have only a slight gap, try putting some pressure on the locking lever (un-locking).
Weather Man is offline
post #12 of 16 (permalink) Old 04-16-2019, 11:20 PM Thread Starter
Neelyrc's Avatar
Date registered: Jan 2019
Vehicle: 1988 560SL, 1969 280SL(113)
Quoted: 13 Post(s)
Here is another solution. Cut the hard plastic wall anchor to a length to fit the gap. Split the saved piece with the box cutter. Insert a small nail in the split to hold it open enough to slip on the cable in the gap. Add a drop of super glue and remove the nail. Maintain pressure on joint until glue is dry. Voila!!
Works fine, we will see how it holds up.
ID:	2505190   Click image for larger version
Neelyrc is offline
post #13 of 16 (permalink) Old 04-17-2019, 02:14 PM
oncebitter's Avatar
Date registered: Jan 2010
Vehicle: 1987 560SL (L.Tonk) [92,700 miles]
Quoted: 24 Post(s)
Originally Posted by Fonzi View Post
Itís a ton easier than properly adjusting the wire.
No truer words have been spoken. I went from "Oh, aren't those Germans clever!" to inventing new curse words over the space of 20 minutes until I got it sorted.
oncebitter is offline
post #14 of 16 (permalink) Old 04-17-2019, 02:47 PM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
I had the same problem with my hood release. I used a tie-wrap to fill the gap. No gluing, no splitting, just insert the tail end of the tie-wrap into the head of the tie-wrap with the exposed wire captive inside the tie-wrap loop and pull the tie-wrap closed until the clicking stops. Done.
If you need to take up more room, add a second tie-wrap.
Nobody gets out of this life alive.
Jyuma is offline
post #15 of 16 (permalink) Old 04-17-2019, 02:50 PM
Franco380's Avatar
Date registered: Sep 2017
Vehicle: 1985 380sl
Quoted: 23 Post(s)
If you feel adventurous you can remove the four nuts on the mechanism, pull the cable and add a few of those little washers you use with pop rivets. I have to admit I do like the cable tie...
Franco380 is offline
post #16 of 16 (permalink) Old 04-18-2019, 01:05 PM
longbeach1's Avatar
Date registered: Dec 2015
Vehicle: 2003 E320 4matic wagon; 1979 450 SL
Quoted: 41 Post(s)
Just removed hard top yesterday and was having a little trouble withe rear catch. So,I'm thinking I have no trouble with soft top. So we lifted straight up on the rear first and it came right out. which is the way the soft top releases. I'm sure most know this already but thought I would throw it out there..
longbeach1 is offline
Hard top rear only locking on one side Alan67 R129 SL-Class 18 05-17-2017 06:18 AM
W124 soft top manual operation 1994 E320 Cabriolet KBelov W124 E,CE,D,TD Class 207 05-06-2015 05:58 AM
Hard Top and Soft Top leak at the front rubber seal. darraghodonnell R129 SL-Class 14 10-10-2011 04:06 PM
SERVICE MANUAL & INDEX 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 3 08-29-2008 12:40 AM
Hard Top switch, console removal. williamdenson R129 SL-Class 2 07-02-2006 05:04 AM
