Sad Tranny...seeking guidance - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 04-14-2019, 06:47 PM Thread Starter
ehawk01's Avatar
Date registered: Feb 2016
Vehicle: 1983 380SL
Quoted: 67 Post(s)
Question Sad Tranny...seeking guidance
My transmission has been flaring for a while (2-3 months) going from 2nd to 3rd gear. Back in 2016 the same transmission was slipping and overheating. Back then in 2016 I did a fluid change (nasty dark fluid and a good bit of debris in the pan), replaced the filter and added a bottle of Lucas, it seems to function normally until recently.
Last week after a lot of stop and go traffic the transmission began slipping again, in addition to the flaring. Fluid levels are fine. No leaks. Color of the fluid looks ok on the rag when I check fluid levels.
I am planning to replace the K1 Accumulator Spring, modulator, a put in new filter, gasket and fluid to see if that fixes it. I should be able to do all that for around $100.
I did drain the bell housing last time and pump out as much fluid as I could from above through the dipstick hole. Does it make sense to have the transmission flushed instead of just a fluid change? Is there more debris and gunk still in the tranny that is better extracted through a flush? Is it bad to use lucas again in the same transmission?
Or based on the previous tranny issues, should I just bite the bullet and order a rebuilt tranny from Sun Valley?
Is there anything else obvious that I am missing?
ehawk01 is offline
post #2 of 16 (permalink) Old 04-14-2019, 07:24 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Did you check your throttle cable adjustment. Sounds like its too late now.
roncallo is offline
post #3 of 16 (permalink) Old 04-14-2019, 07:26 PM Thread Starter
ehawk01's Avatar
Vehicle: 1983 380SL
Quoted: 67 Post(s)
I did adjust it when replacing the injectors a while back. Could that be contributing to this problem?
ehawk01 is offline
post #4 of 16 (permalink) Old 04-14-2019, 07:38 PM
roncallo's Avatar
Quoted: 297 Post(s)
Throttle cable controls transmission fluid pressure. Gives it higher pressure for higher loads. Could have contributed to the problem if the pressure has been too low for a period of time.
roncallo is offline
post #5 of 16 (permalink) Old 04-14-2019, 07:49 PM Thread Starter
ehawk01's Avatar
Vehicle: 1983 380SL
Quoted: 67 Post(s)
Should I increase tension or lessen tension to improve pressure?
ehawk01 is offline
post #6 of 16 (permalink) Old 04-15-2019, 05:40 PM
roncallo's Avatar
Quoted: 297 Post(s)
Which ever direction the cable moves when the throttle goes to full, make it go more that way, but keep it in range. Best find the adjustment procedure in the manual and see where you are before you start.
roncallo is offline
post #7 of 16 (permalink) Old 04-17-2019, 01:57 PM Thread Starter
ehawk01's Avatar
Vehicle: 1983 380SL
Quoted: 67 Post(s)
Red face So Far So Good....
After adjusting the bowden cable, the flaring is gone. I think I may have over adjusted though, as shifting seems delayed. I will adjust again this evening to see if I can improve the shifting without recreating the flaring.
I will need to take a long drive to see if the slipping returns.
ehawk01 is offline
post #8 of 16 (permalink) Old 04-17-2019, 05:14 PM Thread Starter
ehawk01's Avatar
Vehicle: 1983 380SL
Quoted: 67 Post(s)
Thumbs down Not so fast....
I took the SL for a drive this evening and it seemed initially that the bowden cable adjustment had fixed things. I jumped on the interstate for about 5-10 mins and then I noticed a loss in power (and I think slipping of the tranny). I got off and back on the streets and the loss of power led to a stall. I was able to restart the car and then things ran fine for another few minutes before another stall. I was able to get back home by driving real nice and easy.
Clogged tranny filter maybe? I have not swapped fluid yet.
ehawk01 is offline
post #9 of 16 (permalink) Old 04-17-2019, 05:30 PM
roncallo's Avatar
Quoted: 297 Post(s)
Doesn't hurt to try.
roncallo is offline
post #10 of 16 (permalink) Old 04-18-2019, 09:19 PM
Jack Rushing's Avatar
Date registered: Apr 2009
Vehicle: 1985 500SL. Previous cars-190SL, 230S, 250SE, (2) 300SDs
Quoted: 14 Post(s)
Don't know if this will help or not, but I think it is worth a try. About two years ago the line busted from the transmission to the radiator on my car, and I drove it about five miles to my house. I had the line replaced but the transmission would not shift after servicing it. I put a can of Seafoam in it and started running it. After about two days it started shifting normally, and has been performing well ever since.
Jack Rushing is offline
Euro headlights : seeking pre-purchase guidance, please. arakel W201 190-Class 14 06-20-2007 09:42 PM
Seeking price guidance 1995 E420 Shyamalr W124 E,CE,D,TD Class 0 02-27-2007 02:08 PM
Seeking price guidance for 1986 560 SL Shyamalr R/C107 SL/SLC Class 8 02-20-2007 12:17 PM
Seeking price guidance 1986 560 SL Shyamalr R129 SL-Class 1 02-18-2007 11:50 AM
