High Beams not Working - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-11-2019, 10:28 AM Thread Starter
dhorton66's Avatar
Date registered: Mar 2019
Vehicle: 1985 380SL
Quoted: 4 Post(s)
Any suggestions what may be causing my brights not to work? New bulbs, Not getting a 12V reading on either fuse contact when brights switch engaged or not, fuse is good. When brights are switched on fogs and low beams shut off, just no high beams though.
dhorton66 is offline
post #2 of 5 (permalink) Old 04-18-2019, 10:35 AM Thread Starter
dhorton66's Avatar
Vehicle: 1985 380SL
Quoted: 4 Post(s)
No one has had this issue? I am thinking maybe in the blinker/Brights switch?
post #3 of 5 (permalink) Old 04-19-2019, 11:51 AM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 368 Post(s)
I have not had experience with this - going to the fuse box was smart. I would put a meter on the rotary light switch next, followed by the connector for the combination switch. Do you have a copy or access to the ETM for your car?
Page 112 is relevant to your symptoms - attached
Brad Cushman
73 450 SL
cushjbc is online now
post #4 of 5 (permalink) Old 04-19-2019, 12:14 PM Thread Starter
dhorton66's Avatar
Vehicle: 1985 380SL
Quoted: 4 Post(s)
Thanks, I did not have this schematic.
post #5 of 5 (permalink) Old 04-19-2019, 01:51 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 109 Post(s)
Does the high beam flash function work? Should work independent of the light switch.
rowdie is offline
Simple question? How to keep high beams on? tusabes W220 S-Class 2 10-09-2015 06:25 AM
Turn signal switch- high beams statred450sl R/C107 SL/SLC Class 6 03-17-2014 03:53 PM
1999 slk230 horn and high beams not working cpairways R170 SLK-Class 2 11-05-2009 08:36 PM
test Jillian80 Test 5 06-09-2008 11:28 AM
Bu-Xenon Question.. High Beams not working.. AC_ML W163 M-Class 5 09-26-2005 06:19 AM
