380SL 1984 Stalling when accelerating from standstill when engine hot. - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 04-10-2019, 06:12 AM Thread Starter
ed9msi's Avatar
Date registered: Sep 2014
Vehicle: 1984 380SL
Quoted: 4 Post(s)
Hi, My 380SL from 1984 is running really nice and has only gone about 50.000 miles. It's untouched in mint condition and I've had it since it was new.
The only problem i have with it since the last 5 years or so is that once it warms up and you stop at an intersection or stoplight, when you hit the accelerator hard or just slightly it stalls. To keep it from stalling you have to have one foot on the brake and touch the accelerator pedal back and forth to stop it from going down to idle. It's also harder to start the engine when it's warm since it doesn't want to ignite, now whether that is because it gets to much or to little gas i don't know. Apart from this it runs beautifully on all cylinders and accelerates all the way up to the red mark on the tachometer.
During the last 5 years i've changed the sparkplugs, wires, rotor, distributor cap, injectors and seals. The injectors where changed since an old mechanic thought some might leak causing this issue. I've also ruled out that there would be some leakage on the intake side by spraying "start gas" (a can with some ignitable gas to help engines start) around the engine bay without any change in revs. Last week i rebuilt the AAV after reading about it here on this forum so that one closes nicely to. The idle adjust changes the revs nicely so that seems ok to.
Any ideas where i should continue looking?
One more thing that struck me, many years ago an aftermarket alarm system was mounted and the company said they have to disconnect the vacuumdriven locking of the doors since they mounted solenoids in the doors instead. I don't know how they did it and the company's not around anymore but the vacuumdriven locking of the gascap and trunk also stopped working after their intrusion into the vacuum system. Could this have anything to do with it?
ed9msi is offline
post #2 of 26 (permalink) Old 04-10-2019, 07:18 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 282 Post(s)
Since it idles okay and it runs okay, your timing is good and you have sufficient fuel pressure. The symptom is of fuel starvation but only initially, which maybe points to a minor clog somewhere in the delivery system. Is it getting worse or staying the same? Try a new fuel filter or check your return line. Is your emission system okay? A mal/non-functioning O2 sensor might cause it to flood. Miles-per-liter holding up?
Weather Man is offline
post #3 of 26 (permalink) Old 04-10-2019, 07:50 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 557 Post(s)
Don't rule out leaks on the intake system. There are a lot more components that live deeper in block valley that can leak. Spraying starter fluid won't reveal those leaks.
Start with a smoke test and then a fuel pressure test. Avoid the temptation to mess with the metering screw until these two systems are in spec.
Also, did swedish spec cars come with catalytic converters? I could have sworn it was NA, Aus, Jap, and Sweden that had detuned cat'd cars. Paging Dr @rowdie
okyoureabeast is offline
post #4 of 26 (permalink) Old 04-10-2019, 08:47 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
As far as I know only the US 107s had catalytic converters in 1984. Kind of iffy in Sweden. I thought it started in '85 there.
Hard warm start is a normal symptom of a failed accumulator.
An '84 380SL should have an electronically controlled idle valve (ICV) and not an AAV.
rowdie is offline
post #5 of 26 (permalink) Old 04-10-2019, 06:46 PM
joser85's Avatar
Date registered: Feb 2018
Vehicle: 1985 380sl
Quoted: 17 Post(s)
When I bought my 85 380sl cold starts and hot starts were great, but warm starts were stubborn, meaning I had to really crank it to get it started. Replacing the fuel accumulator solved this nicely.
joser85 is online now
post #6 of 26 (permalink) Old 04-11-2019, 01:19 AM Thread Starter
ed9msi's Avatar
Vehicle: 1984 380SL
Quoted: 4 Post(s)
Thank you all for the many replies, I've posted on 2 Swedish Mercedes forums in the last couple of years with very limited feedback so i'm glad to see that this Mercedes forum seems to have a lot of knowledgeable people.
It's staying the same i would say.
I changed the fuel filter in 2001 but that's only about 12000 miles ago, I'll change it again, any special brand that is superior to others that you could recommend?
How exactly should I check the return line? Just disconnect it and put compressed air through it? Any picture where it's located under the hood?
The emissions have been within the allowed limit every time the state inspection has been done (once a year) but they only measure CO level since it doesn't have an O2 sensor, it runs on "leaded" fuel.
"Miles-per-liter holding up?" If you mean what mileage i get, it's been about the same during the years meaning somewhere between 11-15 liters/100 km depending on the drive conditions so 16-21 miles/gallon.
What's a smoke test? Same as emission test? They only measure CO on these old cars without the catalytic converters but the CO was 3,0 in 2013, 1,0 in 2015 and 1,1 in 2017 so it's lower now indicating leaner mixture?
Is there any instruction on how to do the pressure test on these cars?
Which metering screw do you mean?
Where is the accumulator located and does anybody have an OEM number for it? I've only done basic service on this car before so still have a lot to learn but I would say it's an AAV that i rebuilt, attaching pic.
ed9msi is offline
post #7 of 26 (permalink) Old 04-11-2019, 07:19 AM
Vehicle: 1984 380SL
Quoted: 557 Post(s)
Not at all like an emissions test. A smoke test is when smoke (as in literal smoke) is piped into the intake to reveal leaks in the intake system.
Dollars to donuts, you probably have a leak deep down where the plenum connects to the upper block. There are rubber donuts that go bad down there. Especially at 50k miles, they may be original.
A smoke test would reveal those leaks by flooding the area and coming out.
I would replace everything you need to replace along the way since so much has to be removed.
Does your car have a catalytic converter?
post #8 of 26 (permalink) Old 04-11-2019, 07:33 AM
Vehicle: 1984 380SL
Quoted: 282 Post(s)
My goodness Ed, you're running leaded gas?! Fuel filters are everywhere, cheap too. Bosch, I think. Forget the return line because Beastie, I like your idea of a vac-leak near the intake. Press the gas and the motor twists a little, admitting air; it takes a moment for the electronic mixture control to overcome the sudden extra air and hence the hesitation.
Good luck!
post #9 of 26 (permalink) Old 04-11-2019, 07:53 AM
rowdie's Avatar
Quoted: 106 Post(s)
The accumulator is above the fuel filter. Should be the same as the US model but verify number 000 476 04 21
That is an AAV. Has your engine or intake been changed sometime in the past?
Edit...Never mind. I read it is untouched and you have owned it since new. All the 380SLs I could find on EBay in Germany and the UK had the electronic idle control valve including 1981. The only 380SL/Cs I have heard of that had an AAV and idle adjustment screw are the first ones in 1980.
rowdie is offline
post #10 of 26 (permalink) Old 04-11-2019, 12:08 PM
Vehicle: 1984 380SL
Quoted: 557 Post(s)
I don't think these cars, even the high spec'd euro models, were designed to run on leaded gas.
That might be part of the issue right there.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
joser85
Why is my car running hot? ScottinSoCal R/C107 SL/SLC Class 18 08-17-2014 11:16 AM
Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
Desperate to understand cost of engine... PopcornDude W124 E,CE,D,TD Class 18 07-18-2009 09:38 AM
190e hood release rdjarnagin W201 190-Class 7 03-12-2007 09:27 PM
New V8 diesel formally announced GregW / Oregon W164 M-Class 0 05-20-2005 09:00 PM
