What have you done to your R107, TODAY ... - Page 16 - Mercedes-Benz Forum
post #151 of 181 (permalink) Old 07-09-2019, 12:40 AM
ed9msi's Avatar
Date registered: Sep 2014
Vehicle: 1984 380SL
Quoted: 20 Post(s)
Originally Posted by Jyuma View Post
Spray it with clear coat and leave it that way. Gotta be better than black.
I agree, it looks great!!
ed9msi is offline
post #152 of 181 (permalink) Old 07-09-2019, 06:25 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 759 Post(s)
Premium Member
Originally Posted by ed9msi View Post
How do you know when the steering damper needs to be replaced? Any pictures of it and where is it located?
Located under the car connected to the tie rods. It runs perpendicular to the chassis just aft of the front wheels.
Disconnect one end and see if it move easily in and out or if it resists motion like a shock absorber. If it doesn't resist motion it's bad. If it's leaking it's bad. If it's 35 years old it's hard to believe it's not bad.
On second thought... just replace it.
It's like this one... it may even be this one. https://www.ebay.com/itm/Steering-Da...924560a547aa10
Nobody gets out of this life alive.
Jyuma is offline
post #153 of 181 (permalink) Old 07-09-2019, 03:23 PM
Date registered: Jun 2019
Quoted: 13 Post(s)
Took the top off of my 450sl and figured out how to raise the rag top. Got it out and latched the front but couldn’t latch the back! It was shrunk!
Terrybrown is offline
post #154 of 181 (permalink) Old 07-09-2019, 05:09 PM
joser85's Avatar
Date registered: Feb 2018
Vehicle: 1985 380sl
Quoted: 22 Post(s)
Originally Posted by cushjbc View Post
My coolant reservoir was the plastic type that had yellowed with age as they all do. Several years ago I found a brass one in a salvage car. These are supposed to be painted black. I stripped this tank in preparation for that but started liking the idea of a polished brass tank.
Attachment 2525808
I don't know if I will keep it this way or even keep it in service on this car . . . just messing around in the garage yesterday.
I noticed that brass reservoir when I "helped" you with your AC woes a couple weeks ago and had intended to ask about it, but the conversation went elsewhere as they do. Was going to ask if that was the standard look for those things in a 450, but now you've answered my question. In any case, I think it looks pretty sweet!
joser85 is offline
post #155 of 181 (permalink) Old 07-09-2019, 05:12 PM
joser85's Avatar
Vehicle: 1985 380sl
Quoted: 22 Post(s)
Letting it sit in the sun for a bit should loosen it up a bit.
joser85 is offline
post #156 of 181 (permalink) Old 07-09-2019, 05:53 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Don't tighten the front completely then try the rear.
rowdie is offline
post #157 of 181 (permalink) Old 07-10-2019, 01:27 AM
ed9msi's Avatar
Vehicle: 1984 380SL
Quoted: 20 Post(s)
Thanks, but how can you feel that it's bad when you're driving the car?
ed9msi is offline
post #158 of 181 (permalink) Old 07-10-2019, 06:04 AM
benztag's Avatar
Date registered: Mar 2018
Vehicle: 1990 300E 4Matic, 1987 560SL
Quoted: 111 Post(s)
You will feel a wobble through the steering wheel (from subtle, as in my case to severe if the damper totally fails) for a second, or two after going over a bump, or undulation until the suspension settles itself.
benztag is offline
post #159 of 181 (permalink) Old 07-11-2019, 03:27 AM
ed9msi's Avatar
Vehicle: 1984 380SL
Quoted: 20 Post(s)
Thanks I'll try that. Since one member mentioned that if the damper is 35 years old it's shot, I got to think what else should be changed on these cars not due to mileage but only because of age. What i typically mean is parts made of rubber and maybe plastic that dry or get brittle because of age. Is there maybe a list of this that someone has seen or made?
ed9msi is offline
post #160 of 181 (permalink) Old 07-11-2019, 03:42 AM
Premium Member
Jyuma's Avatar
Quoted: 759 Post(s)
Premium Member
That would be a very long list but tops on that list would be chain guides, cam lobe oil tube fittings, throttle linkage ball joints, followed by every other plastic or rubber part including hoses, belts, pneumatic connections, engine mounts, sub-frame bushings, flex disks etc. etc. etc..
You could drive yourself crazy (or go broke) replacing all the age related failure points, but the ones with the potential to cause catastrophic engine failure are chain guides and oilers.
Jyuma is offline
R107 vs. R129? Long time R107 owner considering R129 S320L1999 R/C107 SL/SLC Class 40 11-03-2015 06:15 AM
"Q" regarding R107 tri-y Chicky R/C107 SL/SLC Class 4 02-24-2014 01:34 PM
Russia Today Putin's Weapon in the War of Images Teutone Off-Topic 4 08-15-2013 06:25 AM
A farewell warning from fifty years ago today... Zeitgeist Off-Topic 3 01-17-2011 04:16 PM
Anyone here also own a SL (1971-89) R107? 81bobby300D W123 E,CE,D,CD,TD,TE Class 15 02-05-2009 07:04 AM
