Advice on changing single row chain? - Mercedes-Benz Forum
post #1 of 32 (permalink) Old 04-08-2019, 10:38 AM Thread Starter
frazierfrazier's Avatar
Date registered: Aug 2009
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Been hearing the death rattle last few startups and my chain is indeed loose and there is scoring on the covers. I know some of you have very strong convictions about this subject, but for me and my situation (no garage, limited finances) it makes the most sense to just change the chain, tensioner and guides, so that’s what I’m doing. And no, I will NOT attempt to start it up again until it’s done
I have watched panzerpuff’s video on timing chain service probably 15 or more times over the last few months preparing myself and read many threads here and elsewhere. I have not seen much about single row chain service, though. I think one of you guys mentioned somewhere that the single row is “more difficult because it has a way of jumping teeth on the cam gear”, but that’s really all I could find.
So, anything I should look out for, or is specific to my model year? I’ve ordered the Febi kit which includes everything. Got the stud puller for guide rails. Does the single row need to be riveted? I think I read somewhere that the master link does not use circlips.
I’m honestly very excited for this job! It was a mere three years ago that I was proud of myself for doing a tune up!
cwmoser likes this.
frazierfrazier is offline
post #2 of 32 (permalink) Old 04-08-2019, 11:52 PM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 369 Post(s)
Panzerpuff's videos are always good gouge - never heard of riveting a new chain, circlips are what I had when I did it. I highly recommend a helper on this. My son pitched in and helped me keep everything moving nicely.
I still remember my engine running rough after this job - I thought I had done it wrong. I quickly found #1 and #2 spark plug wires crossed and was happy after I figured it out.
Brad Cushman
73 450 SL
cushjbc is offline
post #3 of 32 (permalink) Old 04-09-2019, 09:18 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Originally Posted by frazierfrazier View Post
I’m honestly very excited for this job! It was a mere three years ago that I was proud of myself for doing a tune up! [IMG class=inlineimg]/forums/images/BenzWorld2/smilies/tango_face_surprise.png[/IMG]
From tune ups to chain replacements. We really are an asylum.
Any reason why you won't go for the double chain upgrade if you're DIYing? Anytime I've cheaper out, i found myself having to go back and do it again.
Get the FSM article on this. Also, your friendly local library will have access to Alldata on the computers. I would pay them a visit and see if they have this job in there. Color photos and better English explanations are always a good thing!
okyoureabeast is offline
post #4 of 32 (permalink) Old 04-09-2019, 11:15 AM
Franklyspeaking's Avatar
Date registered: Feb 2015
Vehicle: 1998 C280; 1987 560SL
Quoted: 83 Post(s)
I did a chain replacement on my old 240D several years ago. The chain I bought had rivets (I think that was standard then - probably 2001). There is a tool that I rented off Ebay that was supposed to do the job, but I ended up using a hammer and some punches to finish the job. I drove it for several years after without issue.
Nothing wrong with the single chain, but you will need to change it sooner than with a double row chain. My double row chain went 154K (that's when I bought it). Most recommend changing a single row chain every 25K. That would be a lot of years for me and my SL.
Good luck!
Franklyspeaking is offline
post #5 of 32 (permalink) Old 04-09-2019, 11:58 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 744 Post(s)
Premium Member
Although it's not optimal, there's no reason not to stay with a single row chain if that's what you decide, but make sure you stay on top of the required maintenance. Regular oil changes with top grade oil and check and replace the guides certainly at the time you change the chain and every 5 years thereafter. Tensioners do go bad so replace it along with the guides.
When I bought my 380 new (in '83) it had a single row chain. I was an idiot and went way too long between oil changes... the chain let go at about 30K. You'd think I would have learned my lesson… nope... the second chain let go at around 80K. The moral being... even with an idiot like me who never changed the oil, the single row chain still lasted 30K to 50K miles.
Pay attention to the oil... that's #1, and pull the covers every year or so and take a look. Chain stretch is a myth... chains don't stretch but the connections between the links wear out and each little bit of additional play adds up and the overall length of the chain increases over time, not from stretch but from wear. Oil, oil, oil, I can't stress it enough and it doesn't matter how many rows your chain has, if you don't change the oil on a regular basis you will have problems with your chain and sprockets... and above all, don't try to get an extra year or two out of your chain guides because you don't put that many miles on the car. Chain guides become brittle and break due to time far more than use.
Whatever you decide... good luck.
Nobody gets out of this life alive.
Jyuma is offline
post #6 of 32 (permalink) Old 04-09-2019, 01:13 PM
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2015 ML250 Bluetec, 62K miles; 1987 560SL, 121K miles
Quoted: 715 Post(s)
Isn't the upgrade to a dual-row chain a pull-the-engine job?
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #7 of 32 (permalink) Old 04-09-2019, 01:39 PM
Premium Member
Jyuma's Avatar
Quoted: 744 Post(s)
Premium Member
You need to remove the timing chain cover which means pretty much everything needs to come off the front of the engine. When I had everything off the front of my 380 it looked to me like I could have pulled the timing chain cover without lifting the engine but I wouldn't swear to it. There might be a few bolts in the oil pan that get in the way... I'm just not sure.
Jyuma is offline
post #8 of 32 (permalink) Old 04-09-2019, 03:14 PM
Vehicle: 1984 380SL
Quoted: 638 Post(s)
I didn't think it is, but considering the amount of removal of the front accessory components it might be easier to do just that.
post #9 of 32 (permalink) Old 04-09-2019, 03:36 PM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1743 Post(s)
When I had my 1983 380SL converted to dual-row timing chain, it was an
Engine out procedure.
Some photos of the process:
ID:	2503184   Click image for larger version
ID:	2503186   Click image for larger version
ID:	2503188   Click image for larger version
ID:	2503190   Click image for larger version
ID:	2503194   Click image for larger version
ID:	2503196   Click image for larger version
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #10 of 32 (permalink) Old 04-09-2019, 04:09 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 111 Post(s)
Conversion is either pull the engine or support it and drop the subframe.
rowdie is offline
Chain guides: Upper, or all with the timing cover off? liviu165 W126 S,SE,SEC,SEL,SD,SDL Class 11 02-06-2016 09:06 PM
Camshaft adjuster & timing chain removal; need advice samosali W140 S-Class 16 02-24-2014 11:36 PM
S600 camshaft sensor error after changing timing chain kerrman W140 S-Class 4 11-24-2013 03:06 AM
Timing Chain Help / Advice needed TBIAgent69 W126 S,SE,SEC,SEL,SD,SDL Class 13 03-14-2012 11:25 PM
Found double row timing chain mulewright W126 S,SE,SEC,SEL,SD,SDL Class 6 04-10-2011 11:10 PM
