New fuel tank nightmare - Mercedes-Benz Forum
post #1 of 50 (permalink) Old 04-07-2019, 05:03 PM Thread Starter
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 706 Post(s)
Premium Member
Today was the day I decided to install the new tank. I've had the old tank in and out of the car a dozen times so no big deal, right? Wrong!!!
I've just about had it with shit parts distributors. I could not get this tank to go in no matter how I tried... so I put the old tank back in... it slipped right in no problem. So I lined the two tanks up side by side to see if I could find a difference. They matched up pretty good until I got to the return tube. The following two pictures tell the story.
Here is the old tank. The red arrow points in the direction the return nipple leaves the tank.
Here is the new tank. The red arrow points in the direction the return nipple leaves the tank.
The return nipple on the new tank is so far off that it didn't even come close to lining up with the hole in the bottom sheet metal it must pass through. I thought (for a second of insanity) of trying to bend the nipple but quickly discounted that option because it was sure to snap off if I tried to bend it that far. So the only other thing to do when you can't make the nipple line up with the hole... you make the hole line up with the nipple. (I can just imagine what a field day Nobby will have with that one).
I elongated the hole with my trusty Dremel.
Turns out even the elongated hole wasn't big enough so I removed the tank again and made the hole even larger. That worked and I was able to mount the tank and bolt it down but when I went to attach the return line hose to the nipple, there wasn't enough room to get the clamp on far enough to get over the barb in the nipple and the hose would just slide right off. So once again I took the tank out and this time I made the hole big enough for not just the hose but the clamp as well. That finally resolved the return line issue but only brought up the next issue... connecting the external filter to replace the in-tank screen that the new tank can't accommodate. After several failures I decided to abandon the in-line filter idea and just go with the direct feed to the damper cage and rely on the existing fuel filter to do the entire job.
I finished up the rest of the assembly, poured the gas I had removed from the old tank into the new tank and started the engine. It cranked for maybe 2 seconds and fire right off. I backed out of the garage and let the engine run for a minute or two before shutting it down. Just as a precaution I looked under the car to see if there were any leaks... that's when I notice the leak. Damn. I stuck a bucket under the leak and decided I had enough frustration for one day. I'll find the leak tomorrow.
Nobody gets out of this life alive.
Jyuma is online now
post #2 of 50 (permalink) Old 04-07-2019, 05:56 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2362 Post(s)
I've matured.
Jyuma likes this.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #3 of 50 (permalink) Old 04-07-2019, 05:58 PM
Bob's Your Uncle!
nobby's Avatar
Anyways, you're doing it wrong.
Maybe you should give this a read.
https://www.goodreads.com/book/show/732026.Sex_101
nobby is offline
post #4 of 50 (permalink) Old 04-07-2019, 06:01 PM
Date registered: Mar 2019
Vehicle: 1998 E300 turbo diesel
Quoted: 12 Post(s)
That's the problem with aftermarket crap, the time and frustration of having to "adapt" an already inferior product. I'd be hitting the scrapyards to get genuine if oem new is out of the question $$ wise. I've had to use the tank sealer stuff before and it does work, just follow directions to a T.
Mr Krabs is online now
post #5 of 50 (permalink) Old 04-07-2019, 06:24 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 600 Post(s)
Hehe, you should his 50 page adventure trying to do just that.
The fuel tank is really Jyuma's achille's heel.
At this point, a crappy aftermarket approximation was really the best outcome given the BS he's put up with.
I'm glad you were able to hack it all together Jyuma!
(and for Nobby to discover that his maturity age is older than 12 )
okyoureabeast is offline
post #6 of 50 (permalink) Old 04-07-2019, 06:33 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
I've matured.
Since when???
Aussiemerc likes this.
rcrmonte3 is offline
post #7 of 50 (permalink) Old 04-07-2019, 06:47 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 380 Post(s)
Talking
Originally Posted by rcrmonte3 View Post
Since when???
Maybe a side effect of the anti fart meds that SWMBO insists he take?
Aussiemerc is offline
post #8 of 50 (permalink) Old 04-07-2019, 07:42 PM
Quoted: 12 Post(s)
I'll have to do my homework and thumb through that thread. I feel his pain for sure.
post #9 of 50 (permalink) Old 04-08-2019, 03:54 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 104 Post(s)
Shoot Jyuma, talking about bad luck! Having read your other adventures around fuel tank I certainly feel your pain buddy - you will get there!
I can also see why electric cars would appeal to you, maybe consider converting the ol' girl to an all electric? ;-)
miko1aj is offline
post #10 of 50 (permalink) Old 04-08-2019, 08:09 AM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 706 Post(s)
Premium Member
Just when you think you've seen everything... this happens;
No, your eyes aren't playing tricks on you... the common wire going to the fuel pump (god I hope it's the common wire) wore a hole in the brand new chrome plated fuel line.
The arrow coming from the left points to the leak in the fuel line. The arrow coming from right points to the wire I pulled away from the fuel line while searching for the leak.
You can't make this stuff up.
Jyuma is online now
Up to 16% of new C-Class weight reduction is due to smaller fuel tank Wimbledon W205 C-Class 2 02-07-2014 04:38 AM
How to Replace the Fuel Pump & Filter JDC-SoCal W163 M-Class 11 12-22-2012 12:28 AM
fuel tank plumbing troca Unimog 7 11-29-2010 10:29 AM
did ya know there are 3 fuel filters? phaster W123 E,CE,D,CD,TD,TE Class 10 06-15-2009 06:24 AM
Fuel Economy 101 philip W124 E,CE,D,TD Class 5 09-26-2004 06:49 PM
