New fuel tank nightmare - Page 5 - Mercedes-Benz Forum
post #41 of 50 (permalink) Old 04-15-2019, 10:00 AM Thread Starter
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 744 Post(s)
Premium Member
Originally Posted by reno4u2 View Post
A couple of things to check/try. Keep in mind this was on a 560SL...two fuel pumps.
Are you sure everything is tight? I had to take a spare 17mm wrench and grind it down to make sure it went over the check valve flats...see pics. Normal wrench on left...thin wrench on right.
You wouldn't think you'd have to on new copper washers but google anneal copper washers. Usually done to return used hardened washers to a soft state. Basically you just heat them up cherry red with a propane torch and let them cool naturally.
Last thing would be to make sure the sides of the banjo fitting are smooth and flat. Long shot here but what the hell. A fine tooth file or sharpening stone would work.
I tightened all connections as far as I could get them. Way tight enough to seal if the washers are soft enough. The Amazon washers are probably too hard. They leaked far worse than the original washers that only slowly dripped. I'm fairly confident that the Autohaus washers will work.
Nobody gets out of this life alive.
Jyuma is online now
post #42 of 50 (permalink) Old 04-15-2019, 11:12 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 106 Post(s)
Understand Jyuma that generic washers failed you, I was just trying to reassure you in a clumsy manner that Autohaus ones will work OK 👍
miko1aj is offline
post #43 of 50 (permalink) Old 04-15-2019, 11:25 AM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 842 Post(s)
Originally Posted by miko1aj View Post
Excuse my ignorance reno4u2 but two fuel pumps in a 560? Holy smoke, that sounds complicated. Are both active in parallel or is it primary / backup circuit?
Actually it's what I would call "in series". Fuel goes into 1 and then down and around under pressure into 2. Leaves 2 and goes to filter..
Name:	DSCN2280_20160312_501a (Medium).jpg
reno4u2 is offline
post #44 of 50 (permalink) Old 04-15-2019, 12:26 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 744 Post(s)
Premium Member
I just noticed an Autohause bag in my spare parts bin marked 007603-012102. The bag contains 10 new unused copper washers measuring 12mm x 16mm x 1.5mm. According to the Autohause website they are a direct replacement for the 2 types of crush washers used in Mercedes fuel pump plumbing. I'm installing them now (fingers crossed).
Success!
No more leaks... no more smell of fuel in the cabin. It's amazing what the right parts can do.
Weather Man likes this.
Jyuma is online now
post #45 of 50 (permalink) Old 04-15-2019, 03:04 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 638 Post(s)
Success!
I too recently had reduced the gas smell to nothing in my car. The fuel system is stupid finicky. Have to use EXACTLY the right hoses, clamps, and washers or else you get a slight smell.
Glad you're at the point of success... hopefully.
okyoureabeast is offline
post #46 of 50 (permalink) Old 04-15-2019, 06:48 PM Thread Starter
Premium Member
Jyuma's Avatar
Quoted: 744 Post(s)
Premium Member
Took a top down drive around the block today... about a mile... it threatened rain the entire ride and it was cold, but I didn't care... my gas wasn't leaking and all I smelled was the sweat scent of burnt hydrocarbons. Hopefully I increased the global temperature by a gazillionth of a billionth of a degree even if only for a nano-second or two.
Jyuma is online now
post #47 of 50 (permalink) Old 04-15-2019, 07:50 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
OH,NO! Adding to global warming! What a terrible person! (NOT)
miko1aj and Jyuma like this.
rcrmonte3 is offline
post #48 of 50 (permalink) Old 04-15-2019, 08:08 PM
joser85's Avatar
Date registered: Feb 2018
Vehicle: 1985 380sl
Quoted: 22 Post(s)
LOL, whoda thunk that an r107 is the elusive climate control knob?
joser85 is offline
post #49 of 50 (permalink) Old 04-16-2019, 01:04 AM
miko1aj's Avatar
Quoted: 106 Post(s)
Reno4u2 - thanks for the explanation, the two fuel pumps look like the same model? I wonder if you'd get away with single fuel pump or are two a must in order to maintain the pressure....
miko1aj is offline
post #50 of 50 (permalink) Old 04-16-2019, 01:07 AM
miko1aj's Avatar
Quoted: 106 Post(s)
Success!
Nice one Jyuma, congrats!
I love that sweet feeling of a surprise "I don't remember having these..." when discovering a gem in the spares cabinet
miko1aj is offline
Up to 16% of new C-Class weight reduction is due to smaller fuel tank Wimbledon W205 C-Class 2 02-07-2014 04:38 AM
How to Replace the Fuel Pump & Filter JDC-SoCal W163 M-Class 11 12-22-2012 12:28 AM
fuel tank plumbing troca Unimog 7 11-29-2010 10:29 AM
did ya know there are 3 fuel filters? phaster W123 E,CE,D,CD,TD,TE Class 10 06-15-2009 06:24 AM
Fuel Economy 101 philip W124 E,CE,D,TD Class 5 09-26-2004 06:49 PM
