Ignition lead insulating hose N 040621 022200 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-07-2019, 02:38 AM Thread Starter
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 104 Post(s)
Hello fellow Mercedesians,
Iíll be replacing ignition leads soon in my M117 V8, and while at it Iíd like to replace the insulating hoses as they are, quite literally, cooked. I think the part is NLA (pending confirmation from dealer) and so I wonder if anyone know of equivalent MB part or perhaps can recommend an aftermarket hose? Iíve searched online but wasnít able to find a black rubber look-alike so Iíll appreciate any thoughts you might have.
ID:	2502570   Click image for larger version
miko1aj is offline
post #2 of 9 (permalink) Old 04-07-2019, 09:41 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
This dealer shows still available https://www.mercedespartsdelivered.c...=040621+022200
Are you assembling the wires yourself? If not I don't think you can get the covers on.
Kingsbourne and maybe some others sell the wire sets with the covers installed
rowdie is offline
post #3 of 9 (permalink) Old 04-07-2019, 10:18 AM Thread Starter
miko1aj's Avatar
Quoted: 104 Post(s)
Thank you Rowdie.
Nope, not assembling them myself.. Worst case I'll slice the new hose open, feed the leads through and then apply some insulation tape to close loop.
The current hose is just hard and brittle.
miko1aj is offline
post #4 of 9 (permalink) Old 04-08-2019, 03:42 AM Thread Starter
miko1aj's Avatar
Quoted: 104 Post(s)
Nice surprise from the dealer - hoses available for €3.87 per piece so I took 4 - 2 for immediate replacement and 2 for a replacement in 10+ years' time
I'll post some pics when they've arrived.
miko1aj is offline
post #5 of 9 (permalink) Old 04-08-2019, 05:00 AM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 362 Post(s)
I'm late to this party but I bought these 2 years ago because they have the sleeves installed.
https://www.authenticclassics.com/Me...uth-007554.htm
I'm sure you will be able to remove one end of whatever ignition leads you have to install the sleeves; no experience with this though.
Brad Cushman
73 450 SL
cushjbc is offline
post #6 of 9 (permalink) Old 04-08-2019, 05:14 AM Thread Starter
miko1aj's Avatar
Quoted: 104 Post(s)
They're great value Brad, thanks for sharing - and numbered as well, that's a nice touch. I'd have gotten them except that I got a new set of leads for ca. $30 off a gent who doesn't need them (extra stock) so couldn't say no to that...
miko1aj is offline
post #7 of 9 (permalink) Old 04-08-2019, 05:32 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 821 Post(s)
There are several sizes of the insulating tubing available. they come in 1 meter lengths
N040621005200
N040621007200
N040621008200
N040621012200
N040621016200
N040621022200
N040621025200
the sizes are the 4-5 from last digits
all very reasonably priced
rumb is offline
post #8 of 9 (permalink) Old 04-08-2019, 05:46 AM Thread Starter
miko1aj's Avatar
Quoted: 104 Post(s)
Thanks Rumb, I let the parts guy know about the 1m length as he reckoned they come in "pieces" rather than "meters" - based on that he ordered 4 units, but sure as hell I don't need 4 meters!
miko1aj is offline
post #9 of 9 (permalink) Old 04-21-2019, 08:12 AM Thread Starter
miko1aj's Avatar
Quoted: 104 Post(s)
So the hose arrived, and the name is correct - it is a hose alright so I had to splice it in order to hide the leads in it. A bit of black insulation tape on either end did the trick.
ID:	2506400   Click image for larger version
ID:	2506402   Click image for larger version
ID:	2506404   Click image for larger version
ID:	2506406   Click image for larger version
miko1aj is offline
Flint GreenT Off-Topic 56 05-09-2019 05:07 PM
How to Set R107 Ignition Timing okyoureabeast R/C107 SL/SLC Class 10 06-25-2017 05:36 AM
Urgent Help - Ignition Lead Replacement General Rommel W140 S-Class 17 02-18-2014 12:56 PM
need info on blown head gasket repair and radiator hose mystery to solve C36AMGHAWAII W202 C36 AMG, C43 AMG 16 01-22-2011 01:57 AM
Intermittent engine stall causes? 500SEL drcvd W140 S-Class 12 12-04-2009 09:26 AM
