560SL wheel alignments. - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 04-05-2019, 06:52 PM Thread Starter
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
Does anyone have a genuine MB document that has the Mercedes Benz wheel alignment procedure and specifications for the 560SL.
The service CD does not have this.
roncallo is online now
post #2 of 16 (permalink) Old 04-05-2019, 06:56 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 595 Post(s)
Not what you're looking for, but your local library will most likely have a subscription to all data if no one can provide the real McCoy.
okyoureabeast is offline
post #3 of 16 (permalink) Old 04-06-2019, 02:49 AM
RLT61's Avatar
Date registered: Jan 2016
Vehicle: 86 560SL
Quoted: 332 Post(s)
I think this is what you’re looking for.
I can scan it and provide a better copy if you’d like.
ID:	2502222   Click image for larger version
RLT61 is offline
post #4 of 16 (permalink) Old 04-06-2019, 04:31 AM Thread Starter
roncallo's Avatar
Quoted: 297 Post(s)
That does look like it. If you can scan me a copy I would appreciate it. Is there a page that discusses how to weight the car. Also what manual is that in?
post #5 of 16 (permalink) Old 04-06-2019, 04:44 AM Thread Starter
roncallo's Avatar
Quoted: 297 Post(s)
I have never seen a local library offer that but definitely worth checking.
Thanks for the heads up.
post #6 of 16 (permalink) Old 04-06-2019, 06:08 AM
RLT61's Avatar
Vehicle: 86 560SL
Quoted: 332 Post(s)
This is the manual.
RLT61 is offline
post #7 of 16 (permalink) Old 04-06-2019, 09:11 AM
Vehicle: 1984 380SL
Quoted: 595 Post(s)
They're generally on the digital subscriptions which can be found on the computers alongside access to digital journals and other publications.
It's pretty rad and worth a visit if you get tired of the bad FSM pictures 😎
post #8 of 16 (permalink) Old 04-27-2019, 02:12 PM Thread Starter
roncallo's Avatar
Quoted: 297 Post(s)
Thanks RTL for posting the service manual.
I liked it so much I purchased one on E-bay for $75.00. Unfortunately it has the alignment specifications and changes to the procedure from previous years but not the complete procedure.
So one thing I was able to get out of the manual was that the alignment tools required were all 115 series tools. As many of you are aware the 107 shares the same front end as the late 60's 115's.
Yes that means my 400HP 650Lb V12 is now sitting on a subframe designed for 65HP 4 cylinder diesels.
In any case it appears that I needed to go back in time to when the suspension was conceived to get the info.
So I found a 1968 114/115 chassis manual on E-bay for $18.00 delivered. Evidently no one wants 114/115 manuals. There definitely is more information available and possibly all I need to get what I want but not really what I would call a detailed procedure.
So I found another manual called the "Tuning and Maintenance Manual" Volume 1. I assume since it is volume 1 that there is a volume 2. I sent a message to the E-bay vendor asking if he can check to see that it has a detailed procedure. Hopefully this will have what I need.
WTF is with MB's manuals. These are the most poorly arranged manuals I have ever used.
post #9 of 16 (permalink) Old 04-27-2019, 07:06 PM
Neelyrc's Avatar
Date registered: Jan 2019
Vehicle: 1988 560SL, 1969 280SL
Quoted: 10 Post(s)
RLT61, did I understand you would scan these pages. Can you post here? Thanks!
Neelyrc is offline
post #10 of 16 (permalink) Old 04-28-2019, 01:52 AM
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 152 Post(s)
Do the procedures in section 40 here help?
https://www.startekinfo.com/StarTek/...ssis_300SD.htm
RaceDiagnostics is offline
Lesson learned on wheel alignments. georgebuhr W202 C-Class 3 05-01-2016 10:54 PM
Nardi steering wheel and 560SL Airbag Steering Wheel slfan1 R/C107 SL/SLC Class 44 03-24-2016 08:32 AM
ABS Sensor test results... mclare W126 S,SE,SEC,SEL,SD,SDL Class 9 02-08-2010 03:26 AM
89 560sl airbag/steering wheel removal, help! rkholt R/C107 SL/SLC Class 7 09-16-2009 04:15 PM
