weather seals? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-11-2019, 05:39 PM Thread Starter
Date registered: Jan 2019
Vehicle: yet to be determined
Quoted: 38 Post(s)
weather seals?
where are the best sources for NEW weather seals IE doors, trunk, side glass, as well as new windshield and rear glass "gaskets"
also anyone got a wiring diagram handy?..id love to see if the car i dragged home has working motors still...switches gone..but everything else electrical still seems to work......build thread coming soon(i assume this forum is best for it)
sh0rtlife is offline
post #2 of 10 (permalink) Old 03-11-2019, 09:22 PM
frazierfrazier's Avatar
Date registered: Aug 2009
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Mercedes oem or donít bother on the seals. URO makes weather seals for the 107, and is the only aftermarket option as far as I know, but they are worthless. Speaking from personal experience, but many others have had unfavorable experiences with URO seals
Walt Williams likes this.
frazierfrazier is offline
post #3 of 10 (permalink) Old 03-11-2019, 10:29 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 597 Post(s)
Originally Posted by frazierfrazier View Post
Mercedes oem or don’t bother on the seals. URO makes weather seals for the 107, and is the only aftermarket option as far as I know, but they are worthless. Speaking from personal experience, but many others have had unfavorable experiences with URO seals
I have the uro seals and installed them. They sell a kit which has everything you'll need.
They're not bad and have been holding up nicely. The A pillar seals went through a revision update so make sure to contact [email protected] if you have the latest ones.
I've been very satisfied with them. You'll definitely need to redo the window adjustments to get a snug fit but worth it on the end.
okyoureabeast is offline
post #4 of 10 (permalink) Old 03-11-2019, 11:10 PM Thread Starter
Quoted: 38 Post(s)
my mistake i should have been more specific, 1974 SLC, i fumbled around their site and found no "kits"..nor could i find front/back window gaskets
post #5 of 10 (permalink) Old 03-12-2019, 08:35 AM
Vehicle: 1984 380SL
Quoted: 597 Post(s)
That's because their site isn't where they sell their wares
Check out rmeuropean.com
and Autohausaz.com
Both are forum sponsors.
This site will have an online copy of the FSM: https://www.startekinfo.com/StarTek/...tedDocId=11883
Your wiring diagram should be in there.
post #6 of 10 (permalink) Old 03-12-2019, 09:28 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
No gasket in front windshield. From what I have read the rear glass is a bitch to install.
rowdie is offline
post #7 of 10 (permalink) Old 03-12-2019, 12:32 PM
willyusa's Avatar
Date registered: Dec 2017
Vehicle: 1988 560SL - 79K miles
Quoted: 5 Post(s)
I'm actually in the process of replacing them all and bought the "premium" set from https://www.theslshop.com/. They seem to be pretty good quality, I've replaced doors, hardtop and a-pillars and b-pillars... am now in the process of replacing the soft-top compartment lid seal. I guess only time will tell, but they look good, and have the cloth material in the right places. Also, one of the door seals got lost in the shuffle when they were picking the shipment and they have been good with communication and working to solve the issue.
Hope this helps!
willyusa is offline
post #8 of 10 (permalink) Old 03-12-2019, 03:07 PM
Walt Williams's Avatar
Date registered: Dec 2015
Vehicle: 1983 380SL (us), Former owner: 1965 190Dc
Quoted: 437 Post(s)
Can you get the rear window out without breaking it? My rear window needs to be re-sealed.
Thanks a Million
Walt Williams
Walt Williams is offline
post #9 of 10 (permalink) Old 03-12-2019, 10:40 PM Thread Starter
Quoted: 38 Post(s)
from my experiance on many cars VS OLD rubber, its rare that it isnt better to slowly cut and trim away at the seal all the way around the glass to get it out...better to destroy a seal than break glass.....besides the seals are rarely in good enough shape to warrent saving
best way i useualy do it is to cut at a 45 deg angle from the body tward the glass, dont cut deep right off , make multiple passes and try pealing the rubber back as it will useualy split and then "rip" all the way around leaving you a window that wil just pop out
Darth V8r likes this.
post #10 of 10 (permalink) Old 03-13-2019, 07:08 PM
cushjbc's Avatar
Date registered: Dec 2010
Vehicle: 1973 450 SL
Quoted: 359 Post(s)
1974 Electrical diagram attached. PM me for a copy of the 1974 ETM which is too large to post here.
Brad Cushman
73 450 SL
cushjbc is online now
300cd seals and weather stripping Hipsubscription W123 E,CE,D,CD,TD,TE Class 12 03-12-2014 08:50 PM
Boot/Trunk and engine bay seals - possible upgrade and replacement harlz W126 S,SE,SEC,SEL,SD,SDL Class 2 08-07-2010 05:10 PM
Atlantic tropical weather activity Botnst Off-Topic 1 08-01-2010 10:38 AM
replacing weather seals docdent R/C107 SL/SLC Class 6 12-28-2009 07:49 PM
Replacing window weather seals 111 coupe 3.5 Tony Vintage Mercedes-Benz 0 02-14-2006 01:44 PM
