Crazy Idle Control Module - Page 3 - Mercedes-Benz Forum
post #21 of 27 (permalink) Old 04-19-2019, 05:42 AM Thread Starter
Walt Williams's Avatar
Date registered: Dec 2015
Vehicle: 1983 380SL (us), Former owner: 1965 190Dc
Quoted: 439 Post(s)
Originally Posted by Jyuma View Post
Long shot.... disconnect the linkage arm to the cruise control.
I had 2 occasions when my engine shot to full throttle... once with me in the car (so I quickly shut the engine off) and once with the car idling in front of my garage (it took several horrifying seconds for me to get to the car and kill the ignition).
I removed the linkage arm that goes to the cruise control (front right of engine) and have never had the problem again. If a faulty cruise control can cause a full throttle condition why not all points in between as well?
It only takes 5 seconds to remove the linkage arm, if you've already checked the usual suspects it's worth a try.
It's the linkage arm that goes from here...
Attachment 2505782
To here...
Attachment 2505780
Also, it wouldn't hurt to check all the throttle linkage pivot points for binding.
Attachment 2505788
Thats a thought. I suppose its possible that the device mounted near the alternator could be getting a phantom signal. I'll pop the linkage off where it connects near the throttle body this morning.
Thanks a Million
Walt Williams
Walt Williams is offline
post #22 of 27 (permalink) Old 04-19-2019, 05:48 AM Thread Starter
Quoted: 439 Post(s)
Originally Posted by okyoureabeast View Post
Walt, when my sensors went the symptom was increased fuel economy not a high idle.
I would look at your ICM first.
Before you drop cash on a programma rebuild, open up the module and try to reflow all of the solder points on the back. You can even check all of the capacitors to see if their resistance matches the cap.
If that's too difficult, you can also send it to JamesDean from this site
Cruise Control Repair
My 2 cents.
These relays are really simple electronics and the things that go wrong are the solder joints and capacitors. James might be able to get it working much more cheaply than a new rebuild.
The ICM unit I have is a 3 year old programma rebuild. The unit that came with the car was for x<=1982 (wrong unit). I doubt programma would warranty their work after 3 years. The coolant sensor I put in is a Uro part and I still think it would be a good stroke to replace it with a proper MB part, as I have been finding Uro parts are not quality.
Thanks a Million
Walt Williams
post #23 of 27 (permalink) Old 04-19-2019, 07:59 AM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 710 Post(s)
Premium Member
Keep in mind, it is a long shot and an unlikely one at that. It's just that it's a real easy thing to try.
Nobody gets out of this life alive.
Jyuma is offline
post #24 of 27 (permalink) Old 04-19-2019, 10:33 AM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 605 Post(s)
My 2 cents.
I too have the Uro coolant sensor and it has been working fine. There are tests you can do in the FSM that will help you narrow dowm which part is actually bad. The coolant temperature sensors was really easy to test with a multimeter.
If anything, I would doubt the quality of the programma rebuilds. I remember reading about their units going bad with w123 climate control and cruise control relays.
When I finally pull my butt out of bed, I'll see if I can source the fsm article for you.
And correction to my first reply, it was increased fuel consumption.
okyoureabeast is offline
post #25 of 27 (permalink) Old 05-01-2019, 07:19 AM Thread Starter
Quoted: 439 Post(s)
My response to this lead was to buy what was described as a working used ICM off of the Bay. I swapped it out aaaaand . . . . so far so good. No high idle. If it continues to idle at the correct level I think will first call Programma and find out what kind of warranty they have. If they're won't stand behind their product, which failed after only 16K miles (racked up in just little over 2 year of regular trips the college campus I was attending), I will simply forget they exist. It would be stupid to continue to buy items from a place thats doing shoddy work.
If Programma won't warranty their product I will try what the video I previously posted suggested and replace the transistors he pointed out and see if this will work.
@Jyuma Removing the cruise control linkage didn't help. It was an easy check though.
Thanks a Million
Walt Williams
post #26 of 27 (permalink) Old 05-01-2019, 09:44 AM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 106 Post(s)
Do you expect a lifetime warranty on a rebuilt electrical part? Something in your vehicle could have contributed to the failure.
rowdie is offline
post #27 of 27 (permalink) Old 05-01-2019, 10:39 AM
rick's Avatar
Vehicle: 2007 ML320CDI, 1959 220SE, 1971 280SL, 1982 380SL
Quoted: 92 Post(s)
As I remember, Programma does a 3 year warranty. Check their website. My experiences with them have all been very positive. Good people.
Rick
rick is offline
Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models GeeS General Mercedes-Benz 45 03-23-2019 06:04 AM
Mercedes Fault Codes... These Will Get You Out Of Trouble......one Day ! ;) Sarge786 V-Class 53 10-22-2017 01:19 PM
Code Reader Tubs300E W124 E,CE,D,TD Class 24 07-02-2012 10:11 PM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
Bad preformance Arotished R170 SLK-Class 13 06-04-2008 09:12 AM
