Any leads on single row cam sprockets? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2019, 01:34 PM Thread Starter
frazierfrazier's Avatar
Date registered: Aug 2009
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Iíve been able to find kits without the sprockets fairly easily, but I can only find dual row cam gears. Anyone know where to find them? Also wondering what yalls thoughts are on going for aftermarket chain, guides, etc.
frazierfrazier is offline
post #2 of 4 (permalink) Old 02-16-2019, 02:24 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 222 Post(s)
Just a question: Why would you want single row cam gears/sprockets when the advice I've seen here is to upgrade to double row?
rcrmonte3 is offline
post #3 of 4 (permalink) Old 02-16-2019, 02:40 PM Thread Starter
Vehicle: 1981 380SL
Quoted: 78 Post(s)
Because to convert to double row is a LOT more labor, requires pulling the engine, and I donít gave the space for that. Single row is not ďidealĒ, but itís perfectly fine and is pretty straightforward/doable for me.
post #4 of 4 (permalink) Old 02-16-2019, 03:09 PM
Premium Member
Jyuma's Avatar
Date registered: May 2017
Vehicle: 1983 380 SL
Quoted: 714 Post(s)
Premium Member
Can you use a dual row cam sprocket with a single row chain? There must be space between the sprockets on dual row so maybe a single row chain will work with a dual row sprocket. Just thinking out loud.
Nobody gets out of this life alive.
Jyuma is offline
Timing Chain Stretch and Tensioner? mbboy R/C107 SL/SLC Class 90 02-27-2015 02:03 PM
Single -or- Double Row Timing Chain? Benz Sage W201 190-Class 9 03-16-2009 06:30 AM
380 single row timing chain musings Thorsten W126 S,SE,SEC,SEL,SD,SDL Class 5 06-24-2008 10:13 AM
Single row timing chain pic request The Doggfather W126 S,SE,SEC,SEL,SD,SDL Class 6 06-01-2007 01:29 AM
Would ML have 3rd row seat again? IcyKool W164 M-Class 6 04-24-2006 06:10 AM
