Duty Cycle error codes - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 02-19-2019, 08:56 AM
Date registered: Apr 2007
Vehicle: 300sl 1987
Quoted: 35 Post(s)
Mmmm page not found on all of them...
107's wiki:
Looking for original backseats + their hardware.
bereng is offline
post #12 of 20 (permalink) Old 02-19-2019, 11:15 AM
Bauk18's Avatar
Date registered: Apr 2017
Vehicle: 560SL 1986 244k miles astral grey / black
Quoted: 99 Post(s)
Originally Posted by Biackbenz300se# View Post
...IMHO one of the best stories on the forum today is Bauk18's about changing a fuel filter and now no start.
Thank you, I do my best
How hard can it be?
Bauk18 is offline
post #13 of 20 (permalink) Old 02-20-2019, 04:31 PM Thread Starter
Date registered: Jan 2018
Vehicle: 1986 560SL 1986 420 SEL
Quoted: 17 Post(s)
I guess I'm technically challenged!
But better yet read Bauk 18's thread. All of the links are in there. That's where I got them from.
Biackbenz300se# is offline
post #14 of 20 (permalink) Old 02-21-2019, 06:48 AM
Vehicle: 300sl 1987
Quoted: 35 Post(s)
Thx a lot! :-)
107's wiki:
bereng is offline
post #15 of 20 (permalink) Old 02-24-2019, 02:21 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 865 Post(s)
Originally Posted by Bauk18 View Post
Yes, you measure DC on pin 2 and 3 of the X11 diag. socket at idle. Ignition on, engine off gives you also a static reading, 70 or 85% (85% = California spec). It's recommended to start with this reading as you can check that your DC meter is reading the off-time of the DC and not the on-time. If you see 30 or 15% you know you are reading the on-time which will give you the wrong indication of a problem.
Duty cycle meter:
Some duty cycle meters show the percentage of the square wave voltage’s ‘on’-time, and others show the percentage of its ‘off’-time. In case of the KE-Jetronic the duty cycle value refers to the square wave voltage’s ‘off’-time. A meter which shows the ‘on’-time would, for instance, read 53% instead of the relevant 47%.
If you’re not sure which version your meter is: With ignition switched on (engine not running) the duty cycle should be about 70% (California: 85%). If the meter shows about 30% (California: 15%), it’s probably the wrong version. And if, while the engine is running, the fluctuating duty cycle drops when the adjustment screw is turned cw, it’s the right version.
So my Fluke 87V meter reads 30.2 with ignition on engine off (pic one). So I am reading on-time not off-time. With engine running I get a duty cycle of 50.2% second pic. Does this mean my off-time reading is actually 49.8%? Is it valid to use the on-time percentage minus 100 percent? If not, how do I get the right version as noted by HD? Should I just tweak the adjustment to get to 50.0%? Is there a reference to a thread that explains this? Thanks for the advice.
ID:	2491772   Click image for larger version
PanzerPuff is offline
post #16 of 20 (permalink) Old 02-24-2019, 02:34 PM
Bauk18's Avatar
Quoted: 99 Post(s)
To be sure what you Fluke is reading, I would suggest to calculate the DC manually with engine OFF / ignition ON with the following formula:
The voltage is converted to duty cycle according to the following formula:
duty cycle [%] = [1 - (Vp3 / Vp6)] * 100
Vp3 = voltage between X11 port 3 & port 2 (or ground)
Vp6 = (battery) voltage between X11 port 6 & port 2 (or ground)
([email protected])
If you get the same % you know your are good, if not then your are indeed reading on-time, -100 gives you off-time, but easier the switch to off-time on you Fluke, as it's a Fluke I can not imagine this is not possible.
EDIT: press the continuity beeper tone button to switch between on and off time.
Secondly, with [email protected], was your % fluctuating?
How hard can it be?
Bauk18 is offline
post #17 of 20 (permalink) Old 02-27-2019, 03:30 AM Thread Starter
Quoted: 17 Post(s)
See what readings you get if you put the common probe into pin #3 and positive into #2. I did this with my Klien meter and get off time readings. But if I am mistaken please set me straight as I just got my meter, my first ever, for Christmas. So I could be wrong.
post #18 of 20 (permalink) Old 02-27-2019, 05:56 AM
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 46k miles, dual roller timing chain. 1986 560SL, red/white, 190K mile.
Quoted: 1731 Post(s)
• 0%: problem with the meter
or diagnostic coupling (X11)
or too rich setting (beyond the EHA’s ‘leaning limit’)
• 10%: TPS (throttle position sensor), throttle fully closed signal
or (if at 2.000 rpm) no/false supply voltage to POT (air flow potentiometer)
• 20%: TPS, ‘throttle fully open’ signal
• 30%: CTS (coolant temperature sensor)
• 40%: no/false output voltage from POT
• 50%: o2 sensor (aside from not having reached its operating temperature yet)
• 60%: car speed signal (displayed during driving or engine still running after driving)
• 70%: CPS (crankshaft position sensor) or EZL (electronic ignition module)
• 80%: IATS (intake air temperature sensor)
• 95%: micro switch of throttle linkage (6-cylinder engines)
• 100%: problem with the meter
or ECU ‘N3’ (missing connection to voltage supply or to ground)
or OVP (overvoltage protection relay)
or o2 sensor signal (short to ground)
or too lean setting (beyond the EHA’s ‘enriching limit’)
Credits to H.D.
What is the meter reading that all is OK?
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is offline
post #19 of 20 (permalink) Old 02-27-2019, 09:17 AM
Bauk18's Avatar
Quoted: 99 Post(s)
When the reading is not static.
If you have a fluctuating reading you know that the "inputs" like coolant temp, 02, full throttle etc are transmitting their values properly to the ECU and being properly received by the ECU, but do remind this doesn't mean you have a problem free CIS system, you can still have as vacuum leak for example, see my personal saga. :-)
How hard can it be?
Bauk18 is offline
post #20 of 20 (permalink) Old 02-28-2019, 01:14 AM
Vehicle: 300sl 1987
Quoted: 35 Post(s)
It's a pity they don't do hands on training + diag + repair either online or somewhere in the world. I found some in Germany, but in German and only for professional qualified mechanics of Bosch services. I wouldn't mind spending one week abroad if I get to master KE ie. Anybody has any leads?
107's wiki:
bereng is offline
K-Jetronic WITH Lambda Overview and Adjustment Myndex R/C107 SL/SLC Class 34 04-01-2019 09:14 PM
Incorrect Duty Cycle and No Accel Enrichment bbpping W201 190-Class 24 01-16-2017 10:10 AM
K-Jetronic air/fuel ratio total mess belstar2003 R/C107 SL/SLC Class 27 05-11-2015 05:28 PM
10% duty cycle with engine running? zviratko W126 S,SE,SEC,SEL,SD,SDL Class 0 09-04-2012 10:30 AM
'91 300CE M104 - O2 and Duty Cycle concerns rgnprof W124 E,CE,D,TD Class 4 08-19-2012 08:45 PM
