SLC rust area questions - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 01-12-2019, 03:23 PM Thread Starter
Date registered: Jan 2019
Vehicle: yet to be determined
Quoted: 25 Post(s)
looking at various years of SLC (mostly 70's)for a project, would love to know where these bodys like to rust out so i can poke and prod one to death and get the cleanest body i can find.....mind you i am NOT afraid of rust and have worked with some seriously rusty alfas and some arcane germans, id just like to avoid as much as possible
so far it looks as if they rust out under the battery like every car on the planet..and some seem to rust out behind the headlights and the belt molding.....but have yet to get a general consensus from a forum like this as to the most prone locations of rust
looking forward to the input
sh0rtlife is offline
post #2 of 26 (permalink) Old 01-12-2019, 06:14 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 575 Post(s)
I'd check... everywhere :P
If it's a US model, check behind the battery tray, under the HVAC cowl vents, interior floor panels, rear wheel arches, jack holes, and remove body panels to check inner fenders.
If it's a grey market import, there can be even crazier places to check.
Others will chime in on some specifics.
On an unrelated note, my first Benz spent its entire life in the North East. Surprisingly, many components such as the vacuum pods, door seals, dash, and other rubbery bits were great! Just the body started to rust apart.
So I got a California car for my r107 experience. Turns out, zero rust! Just every rubber components has completely dry rotted out and the dash looks like crap.
Pick your poison. :/
okyoureabeast is offline
post #3 of 26 (permalink) Old 01-12-2019, 06:27 PM
rcrmonte3's Avatar
Date registered: Sep 2011
Vehicle: 1974 450SL (always needs something!) new djet engine 1991; 1961 Besasie X-3 (being restored)
Quoted: 219 Post(s)
Ditto on the inner fenders. I have found very little rust on my SL--other then the left front inner fender on a car that hasn't seen Winter in 25 years and was thoroughly cleaned (without dismantling the car) within 6 months after I bought it.
Also, if the car hasn't been rustproofed (under the skin) get it rustproofed. Before you spray it, though, get a camera in there to check the unit body structure.
rcrmonte3 is offline
post #4 of 26 (permalink) Old 01-12-2019, 06:51 PM
this might help
manu_argie is offline
post #5 of 26 (permalink) Old 01-12-2019, 07:00 PM
rick's Avatar
Vehicle: 2007 ML320CDI, 1959 220SE, 1971 280SL, 1982 380SL
Quoted: 89 Post(s)
Looking for a rust free California or Nevada car is worth the extra cost and effort. You will thank yourself for years to come. Be careful about the statements from some sellers saying that the car is "rust free". There are too many sellers who think that packing rust holes with Bondo and glueing plastic over rust holes makes the car qualify for a "rust free" description.
Rick
rick is offline
post #6 of 26 (permalink) Old 01-12-2019, 11:30 PM Thread Starter
Quoted: 25 Post(s)
the car WILL be a northwest car as i dont feel the need to drive to arizona, besides ive found a local guy that has litteraly 50+ sl/slcs and will sell me exactly what im after..and "if" i find any suprises is willing to swap/let me cut off patch panels
the biggest trick tho is going in knowing EXACTLY where to look so i can make the best educated guess..cause lets face it..untill you blow a car apart you never truely know...and even then you can send a car to media and find even more hidden treasures....that said tho..my experiance with pacific north wet cars is useualy the interior is moist but typicaly rust free unless "tarped" for some amount of its life
ive delt with muscle cars, 50's 60's 70's , fords, alfas, mopars, porsches, toyotas, even lloyds and ive saved cars that were deemed "unsaveable" id just like to start off knowing where to look and with the best case possible...this will be my first venture into benz
post #7 of 26 (permalink) Old 01-13-2019, 01:50 AM
Date registered: Dec 2018
A 107 will spontaneously rust everywhere, but no two cars are the same (and Ive got three of them).
They just do it slower than an alfa.
Main areas
around the windows front and rear screens
Floors
sills
battery tray
good bits about them is parts are easy to get. But unless you can weld spend every last cent to get the best one you can.
lord_fahrquhar is offline
post #8 of 26 (permalink) Old 01-13-2019, 06:05 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2334 Post(s)
Do fill in your profile.
Originally Posted by nobby View Post
Donítí ever wrestle with a pig. Youíll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #9 of 26 (permalink) Old 01-13-2019, 06:23 PM
bigsky's Avatar
Date registered: Sep 2013
Vehicle: 1984 280sl 5spd, 02 E320 4matic, 79&79 450sl part-out, 78,79,81,83 300CD, 79 280CE
Quoted: 487 Post(s)
Run from anything that looks like this. Yes, that is a line of rust running the length of the car on the ground.
ID:	2481282   Click image for larger version
ID:	2481284   Click image for larger version
ID:	2481286   Click image for larger version
ID:	2481288   Click image for larger version
jsebastian and miko1aj like this.
bigsky is offline
post #10 of 26 (permalink) Old 01-14-2019, 09:17 AM Thread Starter
Quoted: 25 Post(s)
i actualy do ALOT of rust work and fabrication, but give me a nut n bolt and an idea and i can build you anything so yes..i can weld
im going to assume that last example is an east coast rust bucket? since NOTHING out this way ever looks remotely that bad unless its been at the beach its entire life..well..my lloyd looked worse actualy
okyoureabeast likes this.
