OT: OK so I'm lazy. - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 12-29-2018, 08:11 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: -----'83 280 SL----- 5 speed....The PIG
Quoted: 2387 Post(s)
True story:
Just before Xmas...I invited an old neighbor friend (going through a nasty divorce) out for wings and beer.
I got there a little early...so I had a beer while I waited.
Later, when it was time to pay, I realized I had left my wallet at home. So I texted my daughter to walk it over.
Paid the tab and then my daughter assisted me home Thank Goodness she came.
Next day Nobette asked me how many beers I had that I needed assistance.
4 or 5, I think.
Daughter: there were 17 on the bill.
Oh. Well....maybe closer to 9 for me. 20 oz. Stellas.
Mmmm.
Currumbin SL likes this.
Originally Posted by nobby View Post
Don’t’ ever wrestle with a pig. You’ll both get dirty, but the pig will enjoy it.
Originally Posted by rocky raccoon View Post
Soldier on Old Chap. The Pig is you and you are the Pig.
nobby is offline
post #12 of 27 (permalink) Old 12-29-2018, 09:07 AM Thread Starter
Date registered: Jun 2011
Vehicle: 75, 280Sl /5speed
Quoted: 279 Post(s)
Originally Posted by Fonzi View Post
I don’t really “like” this method that is used for 5-lug wheels because it seems to me that the width of the lug hole could make a difference. For example, wouldn’t 5x112 wheels for 14x1.5 studs appear more likely to be 5x114 than 5x112 wheels for 12x1.5 studs?
So this clears up a lot. I have the same visual as Fonzi's, the upper one, that shows the 5 lug being measured from center to center
but without the text that says it's actually to the far side. Changes everything. In case your wondering, my Grandson asked if the common
and readily available 5 x 112 rim could be easily adapted to fit an early Ford 5 x 4.5 (114.3) bolt pattern. He likes that there's so many
different rim sizes and offsets. He's a Hot Rod builder but I hope to turn him to the dark side. Any thoughts??
107merc is offline
post #13 of 27 (permalink) Old 12-29-2018, 09:13 AM Thread Starter
Quoted: 279 Post(s)
Originally Posted by Djenka018 View Post
Thanks, knew there had to be one.
107merc is offline
post #14 of 27 (permalink) Old 12-29-2018, 09:15 AM
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
Quoted: 2346 Post(s)
Make sure the center bore is matched up (with hub rings if required). Wobble nuts/bolts with basically washer cones will assure that the seat doesn’t create twisting pressure on the bolts or studs.
I recently got a set of 5x114 Acura wheels for my wife’s Honda Pilot, and was really surprised at how much variety of available in 5x114. I got a great set of tires and wheels for $170. I guess that can happen with MB wheels, but it would be a smoking deal, unlike Ford and Honda products that are always out there for cheap and very plentiful.
I think trying to fit 5x114 on a 5x112 car makes a lot more sense than going the other way.
My signature:
If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #15 of 27 (permalink) Old 12-29-2018, 11:39 AM
Franco380's Avatar
Date registered: Sep 2017
Vehicle: 1985 380sl
Quoted: 23 Post(s)
Wow guys. 112 mm diameter circle going through the center of each lug hole. Nothing more complicated. Did I miss something here?
Franco380 is offline
post #16 of 27 (permalink) Old 12-29-2018, 12:36 PM
Fonzi's Avatar
I guess so.
There’s no circle drawn on wheels to measure the 112 mm. So my critique is of the commonplace method of measuring for a 5-lug PCD, which is dependent on the size of the hole itself.
My signature:
Fonzi is offline
post #17 of 27 (permalink) Old 12-30-2018, 07:31 AM
Franco380's Avatar
Vehicle: 1985 380sl
Quoted: 23 Post(s)
Sorry. Does that actually work? It seems that any measurement that does not go through the center of the bore would not yield the proper boltbcirvke diameter.
post #18 of 27 (permalink) Old 12-30-2018, 10:24 AM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 297 Post(s)
I cant picture it working. You would get a different answer depending on the stud diameter???
roncallo is offline
post #19 of 27 (permalink) Old 12-30-2018, 11:07 AM
Franco380's Avatar
Vehicle: 1985 380sl
Quoted: 23 Post(s)
That would be my thought roncallo. Measurements are taken on bolt-center to eliminate the need to consider the size of the bore for the bolt or stud. Otherwise it would be apples to oranges. That said, I have never taken the specific measurement mentioned to determine the diameter. I'm lazy, so I look on the rear of the wheel taken off the car. Works every time.
post #20 of 27 (permalink) Old 12-30-2018, 11:22 AM
roncallo's Avatar
Quoted: 297 Post(s)
Sounds like an old close enough rule of thumb that half way work because most studs are close in diameter.
roncallo is offline
